Main : Mechanical : Engine Cam specs
[<   Previous  2497  2498  2499  2500  2501  2502  2503  Next   >]
Cam specs
Cam specsPopular
SubmitterdattodevilMore Photos from dattodevil   Last Update2005/8/18 12:00    Tell a friendTell a friend
Hits3482  Comments3    0.00 (0 votes)0.00 (0 votes)
Cam specs from "smiths regrinds" now Mace engineering
A14force
Posted: 2005/8/18 23:00  Updated: 2005/8/18 23:00
 Re: Cam specs
Which cam did you get Damon?
As much as I hate to admit it, after a bit of research on camshafts, I'm starting to lean towards Kelfords now.
hotrod88
Posted: 2005/8/18 23:41  Updated: 2005/8/18 23:41
 Re: Cam specs
this must be NISSAN motorsports part numbers ,cause I have the same old cam on the E-15. wasn't what I was lookin for ,so I found CO. that regrinds them bigger . I ended up with .492 lift 280 duration ,but could go bigger.
dattodevil
Posted: 2005/8/19 9:20  Updated: 2005/8/19 9:20
 Re: Cam specs
You know where to go to find out what cam I used. And what have you found out that convinced you to go with a non Vern cam
