Front Door Trim Part Numbers
From Datsun 1200 Club
Categories: Body | Catalog
<-- back to Part Numbers Index
Also see: Main articles for usage, photos, cross-reference
Door Cards
Door Handles
Weatherstripping
Moulding (trim molding)
Door Glass Weathershield (visor)
Car
FRONT DOOR TRIMMING (4 DOOR SEDAN)
* C-173 page 92-4 to 92-5 1971.4
39 80900-H1000 ASS'Y-FINISHER, front door (R.H.) 4S, 4ST
40 80900-H1100 ASS'Y-FINISHER, front door (R.H.) (黒 black) 4D, 4DT, 4GT, 4DA, 4GA, 4GX
   80900-H1101 ASS'Y-FINISHER, front door (R.H.) (黄 yellow) 4D, 4DT, 4DA
   80901-H1000 ASS'Y-FINISHER, front door (L.H.) 4S, 4ST
   80901-H1100 ASS'Y-FINISHER, front door (L.H.) (黒 black) 4D, 4DT, 4GT, 4DA, 4GA, 4GX
   80901-H1101 ASS'Y-FINISHER, front door (L.H.) (黄 yellow) 4D, 4DT, 4DA
Truck
DOOR FITTING
27 80830-H1000 WEATHERSTRIP ASS'Y-door (R.H.)
27 80830-H1001 WEATHERSTRIP ASS'Y-door (R.H.) < 80830-H1000
27 80831-H1000 WEATHERSTRIP ASS'Y-door (L.H.)
27 80831-H1001 WEATHERSTRIP ASS'Y-door (R.H.) < 80830-H1001
28 80820-H1000 MOULDING ASS'Y-door outer (R.H.)
28 80820-H3100 MOULDING ASS'Y-door outer (R.H.) <> 80820-H1000
28 80821-H1000 MOULDING ASS'Y-door outer (L.H.)
28 80821-H3100 MOULDING ASS'Y-door outer (L.H.) <> 80821-H1000
29 80825-H1000 CLIP-moulding 8
30 80836-H1000 WEATHERSTRIP ASS'Y-door inside (R.H.)
30 80837-H1000 WEATHERSTRIP ASS'Y-door inside (L.H.)
31 80860-H1000 STOPPER ASS'Y-door glass 2
32 08310-61214 SCREW-with washer (fixing stopper) 2
33 80832-H1000 RUBBER-bumper, door
34 80804-H1000 SCREEN-seal, door inside -8102 2 <> 80804-G1900
   80804-G1900 SCREEN-SEALING,FRONT DOOR 8103-8104 1 <5,0> 80804-G1900
   80804-G1901 SCREEN-SEALING,FRONT DOOR 8105- 2
35 80840-21001 COVER-drain hole 4
36 80886-H1000 RUBBER-door cover (R.H.)
36 80887-H1000 RUBBER-door cover (L.H.)
DOOR TRIMMING
37 80900-H1000 FINISHER ASS'Y-door (R.H.) (up to '71-11)
   80900-H3100 FINISHER ASS'Y-door (R.H.) (from '71-12)
   80901-H3100 FINISHER ASS'Y-door (L.H.) (up to '71-11)
   80901-H1000 FINISHER ASS'Y-door (L.H.) (from '71-12)
38 80919-89900 CLIP-door finisher 6
39 80929-32200 CAP-door finisher clip 6
40 80960-H1001 HANDLE-pull 2
 Fixing pull handle
 41 08310-62042 SCREW 4
 42 08915-43642 WASHER-plain 4
SIDE VISOR
43 K5040-00037 VISOR SET-side (op.)
   K5040-00038 SIDE-visor (R.H.) (op.)
   K5040-00039 SIDE-visor (L.H.) (op.)
LATE DOOR TRIMMING
(LATE) DOOR TRIMMING
フロント ダア トリミング <トリム>
80801
80912-G1900 POCKET-DOOR 8110-8910 BROWN/RH
80912-95W00 POCKET-DOOR 8910- GRAY/RH
80900 FINISHER ASSY-FRONT DOOR,RH
80900-H3100 7510-7803 BLACK
80900-G1060 7804-7907 DARK BROWN
80900-G1660 7908-8104 BROWN
80900-G1901 8105-8910 BROWN
80900-95W00 9810- GRAY
80900A CLIP-FINISHER
80919-89900 -8102 6
02809-19100 8103- 6 <> 80919-89900
80900J CAP-FINISHER CLIP
80929-32200 -8102 6
80901 FINISHER ASSY-FRONT DOOR,LH
80901-H3100 -7803 BLACK
80901-G1060 7804-7907 DARK BROWN
80901-G1660 7908-8104 BROWN
80901-G1900 8105-8910 BROWN
80901-95W00 8910- GRAY
80901F BRACKET-DOOR FINISHER
80914-95W00 8910- 2
80950 HANDLE-PULL,FRONT DOOR
80960-H1001 -7803 BLACK 2
80960-G1060 7804-7907 DARK BROWN 2
80960-G2500 7908-8910 BROWN 2
80960-95W00 8910- GRAY 2
80950A SCREW
01452-00015 9007- 2
80950C WASHER-PLAIN
01311-00155 8910-9007 2
Sedan
1 80830-H1202 ASSY-WEATERSTRIP FRONT DOOR RH SEDAN 2 DOOR 0770-
1 80830-H1200 ASSY-WEATHERSTRIP FRONT DOORRH SEDAN 2 DOOR
2 80831-H1200 ASSY-WEATHERSTRIP FRONT DOORLH SEDAN 2 DOOR
2 80831-H1202 ASSY-WEATHERSTRIP FRONT DOORLH SEDAN 2 DOOR 0770-
3 80834-H1000 SPACER-WEATHERSTRIP FRONT DOOR RH SEDAN 2 DOOR
4 80835-H1000 SPACER-WEATHERSTRIP FRONT DOOR LH SEDAN 2 DOOR
5 80820-H1200 ASSY-MOULDING FRONT DOOR OUTER RH SEDAN 2 DOOR
5 80820-H3600 ASSY-MOULDING FRONT DOOR OUTER RH SEDAN 2 DOOR
6 80821-H1200 ASSY-MOULDING FRONT DOOR OUTER LH SEDAN 2 DOOR
6 80821-H3600 ASSY-MOULDING FRONT DOOR OUTER LH SEDAN 2 DOOR
7 80825-H1000 CLIP-MOULDING DOOR OUTER (8) SEDAN 2 DOOR
8 80836-H1200 WEATHERSTRIP-FRONT DOOR INSIDE RH SEDAN 2 DOOR
9 80837-H1200 WEATHERSTRIP-FRONT DOOR INSIDE LH SEDAN 2 DOOR
10 80860-H1000 ASSY-STOPPER DOOR GLASS (2) SEDAN 2 DOOR
11 08310-61214 SCREW-MACHINE WITH SPRING WASHER M6 (2) SEDAN 2 DOOR
12 80832-H1000 RUBBER-BUMPER FRONT DOOR (2) SEDAN 2 DOOR
13 80804-H1200 SCREEN-SEAL FRONT DOOR INSIDE (2) SEDAN 2 DOOR
14 80840-21001 COVER-DRAIN HOLE (2) SEDAN 2 DOOR
15 80886-H1200 RUBBER-DOOR COVER RH SEDAN 2 DOOR
16 80887-H1200 RUBBER-DOOR COVER LH SEDAN 2 DOOR
17 80900-H7002 ASSY-FINISH,FRONT DOOR RH (BLACK,LG-13 SEDAN 2 DOOR 0173-
17 80900-H7001 ASSY-FINISH,FRONT DOOR RH (BEIGE,LH-20 SEDAN 2 DOOR 0772-
17 80900-H7000 ASSY-FINISH,FRONT DOOR RH (BLUE,LB-211 SEDAN 2 DOOR 0772-
17 80900-H1301 ASSY-FINISH,FRONT DOOR RH (YELLOW) SEDAN 2 DOOR(DX) 1270-
17 80900-H1900 ASSY-FINISH FRONT DOOR RH SEDAN 2 DOOR
18 80901-H7002 ASSY-FINISH FRONT DOOR LH (BLACK,LG-13 SEDAN 2 DOOR 0173-
18 80901-H1301 ASSY-FINISH,FRONT DOOR LH (YELLOW) SEDAN 2 DOOR (DX) 1270-
18 80901-H1900 ASSY-FINISH FRONT DOOR LH SEDAN 2 DOOR
18 80901-H7000 ASSY-FINISH FRONT DOOR LH (BLUE,LB-211 SEDAN 2 DOOR 0772-
18 80901-H7001 ASSY-FINISH FRONT DOOR LH (BEIGE,LH-20 SEDAN 2 DOOR 0772-
19 80919-89900 CLIP-DOOR FINISH (6) SEDAN 2 DOOR
20 80929-32200 CAP-DOOR FINISH CLIP (6) SEDAN 2 DOOR
21 80940-H1100 COMP-ARM REST BLACK #766 (2) SEDAN 2 DOOR (DX)
21 80940-K1002 COMP-ARM REST BLACK #766 (2) SEDAN 2 DOOR (DX)
22 08410-62012 SCREW-MACHINE M6 (4) SEDAN 2 DOOR (DX)
23 08915-13610 WASHER-PLAIN M6 (4) SEDAN 2 DOOR (DX)
24 80517-H1000 SHELD-INSIDE HANDLE (2) SEDAN 2 DOOR 1170-
Coupe
1 80830-H1202 ASSY-WEATHERSTRIP,FRONT DOOR,R.H COUPE 2 80830-H1800
1 80830-H1800 ASSY-WEATHERSTRIP FRONT DOOR RH COUPE
2 80831-H1800 ASSY-WEATHERSTRIP FRONT DOOR LH COUPE
2 80831-H1202 ASSY-WEATHERSTRIP,FRONT DOOR,L.H COUPE 2 80831-H1800
3 80834-H1000 SPACER-WEATHERSTRIP FRONT DOOR RH COUPE
4 80835-H1000 SPACER-WEATHERSTRIP FRONT DOOR LH COUPE
5 80820-H1200 ASSY-MOULDING FRONT DOOR OUTER RH COUPE
5 80820-H3600 ASSY-MOULDING FRONT DOOR OUTER RH COUPE 2 80820-H1200
6 80821-H1200 ASSY-MOULDING FRONT DOOR OUTER LH COUPE
6 80821-H3600 ASSY-MOULDING FRONT DOOR OUTER LH COUPE 2 80821-H1200
7 80825-H1000 CLIP-MOULDING DOOR OUTER (8) COUPE
8 80836-H1200 WEATHERSTRIP-FRONT DOOR INSIDE (2) COUPE
9 80860-H1000 ASSY-STOPPER DOOR GLASS (2) COUPE
10 08310-61214 SCREW-MACHINE WITH SPRING WASHER M6 (2) COUPE
11 80832-H1000 RUBBER-BUMPER FRONT DOOR (2) COUPE
12 80804-H1200 SCREEN-SEAL FRONT DOOR INSIDE (2) COUPE
13 80840-21001 COVER-DRAIN HOLE (2) COUPE
14 80886-H1200 RUBBER-DOOR COVER RH COUPE
15 80887-H1200 RUBBER-DOOR COVER LH COUPE
16 80212-H1800 ASSY-DOOR SASH LOWER RH COUPE
17 80213-H1800 ASSY-DOOR SASH LOWER LH COUPE
18 08410-61012 SCREW-MACHINE TO BODY IN SIDE FIX (4) COUPE
19 08915-13610 WASHER-SPRING LOCK TO BODY IN SIDE FIX (4) COUPE
20 80900-H1801 ASSY-FINISH,FRONT DOOR,R.H (YELLOW) OP.COUPE
20 80900-H1800 ASSY-FINISH FRONT DOOR RH BLACK #1742 COUPE
20 80900-H7101 ASSY-FINISH,FRONT DOOR,RH (BEIGE,LH-20 COUPE 0772-
20 80900-H7102 ASSY-FINISH,FRONT DOOR,RH (BLACK,LG-13 COUPE 0173-
20 80900-H7100 ASSY-FINISH FRONT DOOR RH (BLUE) COUPE 0772-
21 80901-H1800 ASSY-FINISH FRONT DOOR LH BLACK #1742 COUPE
21 80901-H7100 ASSY-FINISH FRONT DOOR LH (BLUE) COUPE 0772-
21 80901-H1801 ASSY-FINISH,FRONT DOOR,L.H (YELLOW) OP.COUPE
21 80901-H7101 ASSY-FINISH FRONT DOOR,LH (BEIGE,LH-20 COUPE 0772-
21 80901-H7102 ASSY-FINISH FRONT DOOR,LH (BLACK,LG-13 COUPE 0173-
22 80919-89900 CLIP-DOOR FINISH (8) COUPE
23 80929-32200 CAP-DOOR FINISH CLIP (8) COUPE
24 80940-H1100 COMP-ARM REST BLACK #766 (2) COUPE
25 08410-62012 SCREW-MACHINE M6 (4) COUPE
26 08915-13610 WASHER-PLAIN M6 (4) COUPE
27 80517-H1000 SHIELD-INSIDE HANDLE (2) COUPE 1170-
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Front_Door_Trim_Part_Numbers"
This page has been accessed 10,484 times. This page was last modified 11:09, 19 January 2022. Content is available under Datsun 1200 Club.
