Sedan grille badges
From Datsun 1200 Club
Category: Body
<-- back to Sedan badges
#Grille Center Ornament
#Grille Left Side Badge (trim badge)
20869.jpgAlbum 20869
Center Ornament
1970-1971 Center Ornament
S (JDM)    #62312-H1026
D (export) #62312-H1626
11318.jpgAlbum 11318
#1972 Center Ornament
22828.jpgAlbum 22828
Early Center Ornament
Early grille center badge
* 1970-1973 B110 Sedan & Van (wagon)
* 1971-1978 B120 Truck (ute)
#62312-H1626 ('D')
#62312-H1026 ('S')
Fixing ornament (2 of each needed)
* 08915-43410 WASHER-PLAIN M4
* 08915-13410 WASHER-LOCK M4
* 08911-10410 NUT M4
62312-H1026 'S' Ornament
62312-H1026 SET-ORNAMENT, radiator grille
19527.jpgAlbum 19527 21120.jpgAlbum 21120
31133.jpgAlbum 31133 31134.jpgAlbum 31134 31135.jpgAlbum 31135 31136.jpgAlbum 31136 31137.jpgAlbum 31137
62312-H1626 'D' Ornament
62312-H1626 SET-ORNAMENT, RADIATOR GRILLE SEDAN
24563.jpgbrochure 11793_4a2f681382129.jpgPost click for topic 24321.jpgAlbum 24321
174_65b7f2b8ecb21.jpgPost 498235 174_65b7f2ce67914.jpgPost 498235 174_65b7f2ecb7f43.jpgPost 498235 174_65b7f2c5a20a1.jpgPost 498235 174_65b7f2e0133dd.jpgPost 498235 174_65b7f2d8b4d60.jpgPost 498235
62312-H3125 ORNAMENT KIT-radiator grille [1972 JDM intricate "S" emblem]
7522.jpgAlbum 7522 22828.jpgAlbum 22828 31128.jpgAlbum 31128
Paint color: some look Red, some Yellow, some in-between, but all have the 62312-H3100 cast number.
It is a plastic casting. This one has all the chrome finish worn off
13057.jpgAlbum 13057
62312-H3100 cast mark
31129.jpgAlbum 31129
08915-43410 WASHER-plain M4
08915-13410 WASHER-lock M4
08911-10410 NUT M4
31130.jpgAlbum 31130 31131.jpgAlbum 31131 31132.jpgAlbum 31132
fitted to Sedan facelift grille
457.jpgbrochure 752.jpgAlbum 752
retrofitted to early grille
23190.jpgAlbum 23190
On the left side of the grille is placed the trim badge
Standard    [no badge]
Deluxe      [no badge]
Deluxe 1972 #62330-H3125
GL          #62330-H2026
GL     1972 #62330-H3325
GX          #62330-H2325
GX     1972 #62330-H3425
22513.jpg#1972 DX
174_6905a8b215cf0.jpg#GL early
28127.jpg#GL 1972
6420_5c245be860d51.jpg#GX Early
25658.jpg#GX 1972
31138.jpg#GX 5 SPEED
62330-H2325 Early GX
GX early (1970-1971) COUPE, SEDAN grille badge [thin]
18053.jpgAlbum 18053 27477.jpgAlbum 27477
compare to thick #1970-1971 badge
29956.jpgAlbum 29956
grille badge has long studs for mounting through the grille
Compare to REAR see-through badge with which has flush-mount pins
174_5d756dcaab01a.jpgrear badge 174_5d756dd73c003.jpgrear badge
Bracket: U-shape
6420_5c245be860d51.jpgPost 490273 6420_5c245c9d038d3.jpgPost 490273 6420_5c245ca5bcc0b.jpgPost 490273
Bracket: L-shape
Bracket: with gasket
Bracket Missing: If the mounting bracket is lost, a length of plumbers tape will do the job (metal strapping tape)
with missing studs
yunakiti-img600x450-1277628693ok47g777311.jpg yunakiti-img600x450-1277628693ybadxo77311.jpg yunakiti-img600x450-1277628693qqw7ym77311.jpg
GX flat badge
This modern GX badge has no pins. It has a design like the early GX front trim badge (with the same black background) but is designed for stick-on applications so won't easily fit the 1200 sedan or coupe grilles. Has sticky tape on the flat back of the emblem.
27825.jpgAlbum 27825 27826.jpgAlbum 27826 27827.jpgAlbum 27827
62330-H2026 Early GL
62330-H2026 EMBLEM-'GL' (1970-1971). Used by #sedan and coupe
27822.jpgAlbum 27822 174_6905a8b215cf0.jpgPost 499102 174_6905a8b746394.jpgPost 499102
background-color: blue, but the paint has usually disappeared after 30 to 50 years in the weather
bolt-on type (rear GL badge looks similar, but is the push-in type)
963.jpgAlbum 963 174_6905a89807c03.jpgPost 499102
26619.jpgcoupe brochure 27374.jpgsedan brochure
M4 studs, nuts and washers
174_6905ab49bd21d.jpgPost 499102 174_6905ab3fbcf25.jpgPost 499102 174_6905ab59b55ed.jpgPost 499102 174_6905ab7c303ba.jpgPost 499102 174_6905ab676c645.jpgPost 499102
62330-H3125 1972 Deluxe
NOTE: 1970-1971 DX did not come with a trim badge on the grille
EMBLEM SET-radiator grille "DELUXE" [1972]
7522.jpgAlbum 7522 25974.jpgAlbum 25974
compare to rear badge 84823-H1000
22513.jpgAlbum 22513
62330-H3425 1972 GX
GX 1972 62330-H3425 EMBLEM SET-radiator grille "GX" SEDAN, COUPE [thick]
Grille 'GX' has long bolts and a bracket, in order bolt it to the grill. The similar rear 'GX' badge has short pins.
Late badge is thick and has compressed font (approximately 71mm wide)
25658.jpgAlbum 25658 29956.jpgAlbum 29956
compare to early 1970-1971 'GX' thin grille emblem
compare to rear see-through badge (short pins) and ~100mm wide
Long bolts for the grille badge
29955.jpgAlbum 29955 29957.jpgAlbum 29957
comes with a clamp plate
29958.jpgAlbum 29958
#Early GL and Late GX
16719.jpgAlbum 16719
62330-H3325 1972 GL
GL 1972 - 62330-H3325 EMBLEM SET-radiator grille "GL" (1972 sedan, coupe)
28295.jpgbrochure 28127.jpgAlbum 28127 28129.jpgAlbum 28129
compare to EARLY rectangular GL badge #62330-H2026
20864.jpgAlbum 20864
factory placement on 1972 sedan grille
457.jpgbrochure 1523.jpgAlbum 1523
placement on Coupe Grille
5266.jpgbrochure
Grille badge has long studs for mounting through the grille with cast mark "62330-H3300"
28132.jpgAlbum 28132 28134.jpgAlbum 28134
Backing plate is either simple flat or the stronger ridged type
28131.jpgAlbum 28131 28128.jpgAlbum 28128 28129.jpgAlbum 28129
original white paint | with paint faded away
28130.jpgAlbum 28130 28133.jpgAlbum 28133
Custom-painted red
28135.jpgAlbum 28135
62330-H7225 GX 5 SPEED
The 1972-only GX5 came with this badge, used on both sedan and coupe
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Sedan_grille_badges"
This page has been accessed 1,071 times. This page was last modified 07:10, 3 November 2025. Content is available under Datsun 1200 Club.
