Insulators
From Datsun 1200 Club
Category: Engine Mechanical
The engine mounting insulators sit between the engine mounting brackets and the crossmember, and provides insulation from noise and vibration. They are designed with a particular rubber hardness, to give a balance between softness and rigidity.
20929.jpgAlbum 20929 20925.jpgAlbum 20925 20940.jpgAlbum 20940 562.gifAlbum 562
Spacers
Spacers may be used to raise the engine height
174_656ebeb0df347.jpgPost 498092 174_656ebe55df7b9.jpgPost 498092
All of the following insulators are interchangeable — they fit any year 1200.
11223-H1000 INSULATOR-engine mounting, front [8 mm studs] $12.70 USD
11223-H5000 INSULATOR-ENGINE MOUNTING, FRONT 7510-8503 [8mm studs]
11223-G1900 INSULATOR-ENGINE MOUNTING, FRONT 8504- [8mm studs]
20928.jpgAlbum 20928
B10 Mounts
As you can see these Datsun 1000 parts are different from newer (B110, etc) mounts.
11223-18001 INSULATOR-engine mounting front
18305.jpgAlbum 18305
POST qik1000 used Ford Laser mounts
Custom engine mounts to suit A14/A15. I used new ford laser upper engine mounts, which are significantly larger/stiffer than the originals. This eliminates axle tramp.
1985-1990 BD/BF Mazda 323, KA/KB Ford Laser Rear Engine Mount (spacing varies from B10 mount)
RH stepped bracket with angle-mount insulator
2569.jpgAlbum 2569
Upgraded Insulators
Puck Type
Many favor puck-style insulators, because they are readily available in polyurethane, although OEM-style new rubber makes for less vibration. Either style insulator (stock or puck) can fit stock L-type or A-type mounts.
Universal puck-style mounts, in rubber or polyurethane
1333_56ea3ebf3aaac.jpgPost 477317
These are the heavy duty engine mounts we were talking about. Broken engine mounts are a common thing in rally cars and this fixes the problem. Mounts are polyurethane and come out of a ford cortina and last for years of competition...Part number MT8156N. Kelpro make them...I usually just go to a good parts place and ask for cortina engine mounts and this is what they give me. Maybe there are two types, these are about 70mm in dia.
Kelpro MT8156N
6215.jpgAlbum 6215
quote: you might want to look at the poly-urathene style mounts. I am using some of a Jag. The part number is at home. but they are heaps wider but no tallers, so they make a good direct replacement, plus they are high temp rated.
Maddat Product No - REM1200F Polyurethane Engine Mounts. Suit 1200 Reversed engine X-member (pair). New revised editions have stainless steel plates and increased re-enforcement with a slightly softer compound.
BRITPART STC434 £2.34
* Land Rover Discovery 1989-1994 V8
18807.jpgAlbum 18807 18808.jpgAlbum 18808
Nissan Revised
CA-style/A10/B310-style has fail-safe sides
1333_56ea3e98347f0.jpgPost 477317
See also: A10 Motor Mount
Tougher B310 insulators have a larger studs and locating pins, but otherwise are the same dimensions as B110 mounts
4689.jpgAlbum 4689
NISMO 11220-RS585 RN32 Skyline RB20DE/RB20DET/RB25DE 2WD
NISMO reinforced competition mounts
1333_56ea40da30d75.jpgPost 477317
Silvia Type
super-insulated, good for engine swaps
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Insulators"
This page has been accessed 2,351 times. This page was last modified 06:13, 5 December 2023. Content is available under Datsun 1200 Club.
