Engine Mounting Part Numbers
From Datsun 1200 Club
Categories: Engine Mechanical | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Engine Mounts
Gearbox Crossmember
Splash Pan
1 11223-H1000 INSULATOR-ENGINE MOUNTING FRONT (2) A12
2 11221-H1000 BRACKET-ENGINE MOUNTING FRONT RH A12
3 11222-H1001 BRACKET-ENGINE MOUNTING FRONT LH A12
4 08915-53810 WASHER-PLAIN FIXING INSULATOR TO (8) A12
5 08915-23810 WASHER-LOCK FIXING INSULATOR TO BRACKET (8) A12
6 08911-20810 NUT-HEX FIXING INSULATOR TO BRACKET (8) A12
7 11321-H1000 ASSY-INSULATOR ENGINE MOUNTING REA A12 MANUAL
7 11321-H1020 ASSY-INSULATOR ENGINE MOUNTING REA A12 AUTOMATIC
8 11322-H1002 MEMBER-ENGINE MOUNTING REAR A12 MANUAL
8 11322-H1020 MEMBER-ENGINE MOUNTING REAR A12 AUTOMATIC
9 08110-61410 BOLT-HEX M6 FIXING INSULATOR TO MEMBER (4) A12
10 08915-13610 WASHER-SPRING LOCK M6 INSULATOR TO (4) A12
11 08911-10610 NUT-HEX M6 (4) A12
12 08154-02510 BOLT-HEX MEMBER TO BODY FIX (2) A12
13 08915-14010 WASHER-SPRING LOCK TO BODY FIX (2) A12
14 08915-44010 WASHER-PLAIN M10 TO BODY FIX (2) A12
15 11335-18000 BOLT-ENGINE MOUNTING REAR INSULATOR TO (2) A12 MANUAL
15 11335-20300 BOLT-ENGINE MOUNTING REAR INSULATOR TO (2) A12 AUTOMATIC
16 08915-14010 WASHER-SPRING LOCK M10 (2) A12
17 08911-14010 NUT-HEX M10 (2) A12
18 62611-H1000 COVER-UNDER,FRONT A12
19 08915-43610 WASHER-PLAIN (4) A12
20 08915-13610 WASHER-LOCK (4) A12
21 08110-62010 BOLT (4) A12
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Engine_Mounting_Part_Numbers"
This page has been accessed 566 times. This page was last modified 00:41, 9 January 2012. Content is available under Datsun 1200 Club.
