Automatic Transmission Valve Part Numbers
From Datsun 1200 Club
Categories: Powertrain | Transmission | Automatic Transmission | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
1 31705-X0410 ASSY-VALVE,CONTROL 3N71B
2 31710-X0410 BODY-UPPER,CONTROL VALVE 3N71B
3 32829-26760 BALL-STEEL (7.938) 3N71B
4 31733-X0100 SPRING-DETENT,MANUAL 3N71B
5 31734-X0100 PIN-SEAT,DETENT SPRING 3N71B
6 31731-X0100 VALVE-MANUAL 3N71B
7 31741-X0100 VALVE-PRESSURE REGULATOR 3N71B
8 31742-X0100 SPRING-PRESSURE REGULATOR 3N71B
9 31743-X0100 SEAT-SPRING,PRESSURE LEGULA 3N71B
10 31746-X0100 PLUG-PRESSURE REGULATOR 3N71B
11 31747-X0101 SLEEVE-PLUG,PRESSURE REGULA 3N71B
12 31825-X0100 VALVE-2ND LOCK 3N71B
13 31826-X0100 SPRING-2ND LOCK 3N71B
14 31724-X0100 PLATE-SIDE,D 3N71B
15 08360-51012 SCREW (3) 3N71B
16 31781-X0100 VALVE-2,3 TIMING 3N71B
17 31782-X0100 SPRING-2,3 TIMING 3N71B
18 31801-X0100 VALVE-THROTTLE VACUUM 3N71B
19 31808-X0100 VALVE-THROTTLE BACK UP 3N71B
20 31809-X0100 SPRING-THROTTLE BACK UP 3N71B
21 31817-X0100 SPRING-SOLENOID DOWN SHIFT 3N71B
22 31816-X0100 VALVE-SOLENOID DOWN SHIFT 3N71B
23 31722-X0100 PLATE-SIDE,B 3N71B
24 08360-51012 SCREW (3) 3N71B
25 31762-X0100 SPRING-1,2 SHIFT 3N71B
26 31761-X0100 VALVE-1,2 SHIFT 3N71B
27 31771-X0410 PLUG-2,3 SHIFT 3N71B
28 31772-X0100 SPRING-2,3 SHIFT 3N71B
29 31766-X0100 VALVE-2,3 SHIFT 3N71B
30 31752-X0100 SPRING-PRESSURE MODIFIER 3N71B
31 31751-X0100 VALVE-PRESSURE MODIFIER 3N71B
32 31721-X0101 PLATE-SIDE,A 3N71B
33 08360-51012 SCREW (3) 3N71B
34 31715-X0100 PLATE-SEPARATOR 3N71B
35 31713-X0100 BODY-LOWER,CONTROL VALVE 3N71B
36 31822-X0100 SPRING-ORIFICE CHECK 3N71B
37 31823-X0100 VALVE-ORIFICE CHECK 3N71B
38 32720-36900 BALL-STEEL (6.35) 3N71B
39 31802-X0100 SPRING-THROTTLE RELIEF 3N71B
40 08360-62512 SCREW (7) 3N71B
41 31728-X0100 ASSY-STRAINER,OIL 3N71B
42 08360-54012 SCREW 1 (10) 3N71B
43 31716-X0100 BOLT (2) 3N71B
44 08911-10610 NUT (2) 3N71B
45 08160-62500 BOLT (3) 3N71B
46 08160-63510 BOLT (2) 3N71B
47 08160-64010 BOLT (2) 3N71B
48 31918-H0101 ASSY-SWITCH,INHIBITOR 3N71B 0172- 2 31918-H0100
48 31918-H0100 ASSY-SWITCH,INHIBITOR 3N71B
48 31918-X0100 ASSY-SWITCH,INHIBITOR (NILES) 3N71B 1272- 2 31918-H0101
48 31918-X0101 ASSY-SWITCH,INHIBITOR (NATIONAL) 3N71B 0373- 2 31918-H0101
49 31919-X0101 GASKET-INHIBITOR SWITCH 3N71B
50 31916-X0100 SEAL-O RING (16S) 3N71B
51 08160-61610 BOLT (2) 3N71B
51 08160-62010 BOLT (2) 3N71B 0172- 0 08160-61610
52 31931-H0101 ASSY-DIAPHRAGM,VACUUM 3N71B
53 31932-X0101 ROD-DIAPHRAGM, L=31 3N71B
53 31932-X0104 ROD-DIAPHRAGM, L=29.5 3N71B
53 31932-X0103 ROD-DIAPHRAGM, L=29 3N71B
53 31932-X0102 ROD-DIAPHRAGM, L=30.5 3N71B
53 31932-X0100 ROD-DIAPHRAGM, L=30 3N71B
54 31933-X0100 SEAL-O RING (26S) (2) 3N71B
55 31941-X0102 ASSY-SOLENOID,DOWN SHIFT 3N71B 1170- 2 31941-X0101
55 31941-X0101 ASSY-SOLENOID,DOWN SHIFT 3N71B
56 31981-E8000 SUPPORT-PARKING ACTUATOR 3N71B
57 31983-E8000 PLATE-RETAINING,PARKING 3N71B
58 31985-E8000 SPRING-BALL,PARKING (2) 3N71B
59 31984-E8000 RETAINER-SPRING,PARKING 3N71B
60 31357-20300 BALL-STEEL (8.731) (2) 3N71B
61 01125-00021 BOLT (2) 3N71B
62 31986-20300 SHAFT-PARKING PAWL 3N71B
63 31991-E8000 PAWL-PARKING 3N71B
64 31988-E8000 SPRING-RETURN PAWL 3N71B
65 31987-E8000 SPACER-PARKING PAWL 3N71B
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Automatic_Transmission_Valve_Part_Numbers"
This page has been accessed 719 times. This page was last modified 04:25, 9 January 2012. Content is available under Datsun 1200 Club.
