There is no page titled ":Air_cleaner". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below 11 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- Emission Controls (28459 bytes)
296: ...C. Air Cleaner). Used on USA 1200 1972-1973 and [[Air_Cleaner#Late_Sunny_Truck|Japan 1200 1989-]]. - Float Level Adjustment (1455 bytes)
17: ...move the air cleaner assembly. For details, see [[Air_Cleaner#Removal|Air Cleaner Removal]] - Intake Manifold (14016 bytes)
274: * old-style (side mounted) [[Air_Cleaner#Part_Numbers|Air Cleaner]] bosses - PCV (10610 bytes)
114: ...[Rocker_cover#19102|rocker cover]] connected to [[Air_Cleaner|air cleaner]] - Air Cleaner (11281 bytes)
20: <br>{{Photo|B110_ATC_air_cleaner.jpg}}
40: ...ld air cleaner, '''first''' remove the hoses as [[Air_Cleaner#Hot/Cold Air Cleaner|outlined below]]
44: #: {{Photo|B110_air_cleaner_bolts.jpg}}
46: #: {{Photo|B110_air_cleaner.jpg}}
54: ...dPost|174_65b7feb7e7a39.jpg|498236|was=Photo\B110_air_cleaner_ATC.jpg}} - Carbon Canister (6509 bytes)
10: {{AlbumLinkH|Air_Cleaner#Late_Sunny_Truck|16888|air cleaner|height=300}} {... - Hitachi Twin Carb Air Cleaners (8034 bytes)
22: {{Photo|blue_air_Cleaner-2.jpg|sightings/forum}}
69: {{Album|13428}} {{AlbumLinkH|GX_Air_Cleaner_Part_Numbers#Japan|29940|parts}}
76: ...ner-1.jpg\sightings/forum}} {{Album|29947|was=Red_air_cleaner-2.jpg\sightings/forum}}
94: ..._air_Cleaner-2.jpg|sightings/forum}} {{Photo|blue_air_Cleaner-1.jpg|sightings/forum}}
96: ...leaner_fitting.jpg|sightings/forum}} {{Photo|A12T_air_cleaner.jpg|sightings/forum}} - Exhaust Manifold (13884 bytes)
174: * Heat shield with [[Air_Cleaner#Hot.2FCold_Air_Cleaner|hot-air tube]] connector and cutout for the [[Car... - Vacuum Leaks (7564 bytes)
54: ...inspect the vacuum hoses. For instructions, see [[Air_Cleaner#Removal|Air Cleaner Removal]].
101: ...ave an [[Emission_Controls#Temperature_Controlled_Air_Cleaner|Air Cleaner Motor]]. If needed, this part can be ... - Heat Riser (5234 bytes)
58: 3. The [[Air_Cleaner#Anti-Icing|Heated Air Cleaner]] (option in most c...
62: ...er''' ([[Emission_Controls#Temperature_Controlled_Air_Cleaner|A.T.C. Air Cleaner]]), standard in USA, keeps the... - Choke Adjustment (8129 bytes)
5: ...g. See [[Emission_controls#Temperature_Controlled_Air_Cleaner|Hot Air Intake]]
23: If adjustment is necessary, first [[Air_Cleaner#Removal|remove the air cleaner]] — it must ...
