<-- back to Japan B210 badges
For the Japan market, the minor update to the Sedan & Coupe was numbered B211 (DEC 1975).
[edit]
Late Sedan
#Grille #Hood/Bonnet #C-pillar #Rear
B211 Sedan Front & Side Emblems | Rear Emblems
[edit]
Radiator Grille
back to #Late_Sedan
62311 08510-51212 SCREW 62312-H7425 JDM ORNAMENT-FRONT SEDAN, VAN [gold 'S' intertwined mark]
[edit]
#LATE #EARLY PB210 gold various white Deeper slant Slant Slantiest flat face raised face flat face single screw long stud two posts
[edit]
62312-H7425
[edit]
Hood/Bonnet
back to #Late_Sedan
For the B211, GX twin carb (GX-T) had hood badge. GX single carb (GX) did not.
Japan 65852 MARK-HOOD 65800-H7510 A14T 'GX-T' Sedan, Coupe
[edit]
65800-H7510
This badge is used by both sedan and coupe, as the hood (bonnet) is identical for both.
similar to: #Side badge, which has two fastening pins
65800-H7510 MARK-HOOD A14T フード マーク
appears to have 3 fastening pins, while the coupe side badge has only two
[edit]
C-Pillar
back to #Late_Sedan
all dates (also used by early sedan) #C-pillar 'Sunny' #C-pillar 'Sunny Deluxe'
1976 tie-bar style badge (also used by early sedan) #C-pillar 'Sunny GL' #C-pillar 'Sunny GX' #1976 'Sunny GX-T'
1977 Medallion type emblems #1977 GL #1977 GX #1977 GX-T
[edit]
C-pillar 'Sunny GX'
[edit]
1976 'Sunny GX-T'
-7701 A14T Twin carb 76854-H5710 RH MARK-SIDE REAR 'Sunny GX-T' S.A14.GX
[edit]
1977 GL
7702- [round emblem] 76854-H7511 EMBLEM-SIDE REAR RH 'Sunny GL' =GTR [2-door] 76855-H7511 EMBLEM-SIDE REAR LH 'Sunny GL' =GTR [2-door] 76854-H7512 EMBLEM-SIDE REAR RH 'Sunny GL' S.A12,A14.GL [4-dr] 76855-H7512 EMBLEM-SIDE REAR LH 'Sunny GL' S.A12,A14.GL [4-dr]
1200 (H74) * GTR GL 4-speed 2-dr * GT GL 4-speed 4-dr 1400 (H75) * H=GT GL 4-speed 4-dr * H=GF GL 5-speed 4-dr * H=GA GL Automatic 4-dr
2D Photos needed of 2-door GL
[edit]
1977 GX
76854-H7514 EMBLEM-SIDE REAR RH 'Sunny GX' S.A14.GX 7702- 76855-H7514 EMBLEM-SIDE REAR LH 'Sunny GX' S.A14.GX 7702-
[edit]
1977 GX-T
76854-H7517 'Sunny GX-T' S.14T.GX 76855-H7517 'Sunny GX-T' S.14T.GX
About GX-T: Twin debut JUL 1976HB211/HKB211 1400 (H75) * H=JTK A14 GX 4-speed Twin * H=JFK A14 GX 5-speed Twin
[edit]
Rear
back to #Late_Sedan
#'NISSAN' rectangle badge #'NAPS' 84890-F2000 #Rear center Trim badge #'1400' badge
[edit]
84814-H7401 MARK-REAR 'NISSAN' diagram IDS: 84815,84819 location: rear left
* B211 JAPAN Sedan * #KB211 JAPAN Coupe * B210 JAPAN #Van OCT 1975- * B310 rear left * S130 280ZX/Fairlady Z hatch * S110 Sylvia/200SX
Similar: * 'NISSAN' over plain rectangle Truck_Badges#Rear 8910- 62311 62392-G1265 'NISSAN' 8910-
[edit]
84890-F2000
Badge for NAPS (Nissan Anti-Pollution System)
- GB211 Rear
- B211 Sedan #Rear
- KB211 Coupe #Rear
- VB210 Van #Rear
84890-F2000 MARK-REAR 'NAPS' [blue/green]
[edit]
EMBLEM-REAR - single-piece (Coupe uses two-piece emblems)
84815 - same as early sedan 79805-H5000 #Rear 'SUNNY' STR, SMDX 79805-H5010 #Rear 'SUNNY deLuxe' 79805-H5100 #Rear 'SUNNY GL' 79805-H5200 #Rear 'SUNNY GX'
84819 - 1976-1977 79805-H751x #Rear 'SUNNY GX-T' Sedan
[edit]
Rear 'SUNNY GX-T'
79805-H7510 ? 'SUNNY GX-T' *S.14S.GX [or 79805-H7515] 79805-H751x EMBLEM-REAR 'SUNNY GX-T' Sedan
[edit]
'1400' badge
diagram ID 84819 84812-H7500 MARK-REAR '1400' A14S,A14T * B211 rear, right side * KB211 rear, right side
[edit]
GX-T Badges
See also: Coupe GX-T Badges
GX-T sedan badges
- #Bonnet GX-T badge (same as coupe)
- #C-pillar GX-T badge
- #Rear GX-T badge
- GX-T steering wheel medallion
