Choke Cable
(Redirected from Choke Linkage)
Categories: Fuel System | Engine Control | Hitachi 306 Carburetor
Since the carburetor is always on the same side of the car, but the choke cable is on different sides for RHD and LHD cars, the cable length is different for RHD and LHD models.
B110 cable dash end
17173.jpgAlbum 17173 29900.jpgAlbum 29900
Carburetor choke cable bracket (early and late versions)
Long RHD choke cable
13914_504c5ad938635.jpgPost 417523
Dash tightening special nut (included with cable)
13914_504c5d73be0ec.jpgPost 417525 willieoec-img600x450-1327299696wgizq26299.jpg
Short LHD choke cable buy at new Datsun parts
1200 Single Carb choke cable buy at Bprojects
1200 Twin Carb choke cable (generic type) buy at Bprojects
twin-choke-wire-2014612-002.jpg twin-choke-wire-2014612-003.jpg twin-choke-wire-2014612-004.jpg
TWIN aftermarket
Length:1790mm
Wire OD: 1mm
Fixed thread OD: 12mm
GX
Hitachi Twin Carb choke cable has a ratcheting mechanism.
18410-H2302 WIRE COMP,-choke control GX
The A12GX used a twin-cable Choke knob. However, you can use the stock single cable with a simple bracket on the carbs to operate both:
20152.jpgAlbum 20152 12996.jpgAlbum 12996
19289.jpgAlbum 19289
PB110
Datsun Sunny Excellent 1400 PB110 with L14 engine
MASK-'Auto Choke' DX/GL Single Carb
* 25250-H2500 -7112 rectangular
* 25250-H2510 7201- round
WIRE-choke control GX Twin Carb
* 18410-H2702 > 18410-H2700
1972 Round "Auto Choke" mask | 1971 rectangular
U00017593481_8_001.jpg 174_5b9d7a428ccef.jpgPost 489454
Sunny Truck
Choke warning lamp added to Dash#Late April 1978 for E-level emission control
  LENS-WARNING LAMP 24250-H2500 (Auto Choke Lens)
The dash 'Auto Choke' is a blank plate for the choke knob hole. Same as the #PB110 part?
174_5d65ee6af3492.jpgPost 492391 27038.jpgAlbum 27038
OCT 1989 updated with EX TEMP warning light
174_5d65ee9653493.jpgPost 492391 174_5d65ee8b19b1b.jpgPost 492391
Engine Control Part Numbers
Cable
  • 18410-H1001 WIRE COMP, choke control RHD 830 mm
  • 18410-H2302 WIRE COMP, choke control GX twin carb
  • 18410-H1602 COMP-WIRE CHOKE CONTROL LHD
  • 00951-10400 GROMMET
Choke Knob
  • 18415-H1001 ASSY-KNOB CHOKE CONTROL
  • 18415-H2300 ASSY-KNOB-choke control GX superceded
  • 18415-H1000 ASSY-KNOB-choke control GX from 72-12 (backfits to 18415-H2300)
Comparison: 610 JAPAN SSS Twin Hitachi (all Single Carb 610 used auto choke)
  • 18410-U0801 SSS (except E-all)
  • 18415-U0810 KNOB
  • 18418-U0800 BRACKET
  • 24250-89929 GROMMET-rubber
Comparison: 510 JAPAN (some used Throttle Control instead)
  • 18410-A0600
  • 18410-A4901 from '72 model
  • 18410-A4900 PY,JPY
  • 18410-A5100 SSS Twin Hitachi
  • 18415-A4900 KNOB
Linkage
Hitachi DCG306 Carburetor choke linkage variations are many. Even during the Datsun 1200 run there were several varitions, with more coming with the B210.
Choke cable right-hand vs left-hand entry
22277.jpgAlbum 22277
Choke cable left-hand entry (very early)
22275.jpgAlbum 22275
Choke cable right-hand entry
22274.jpgAlbum 22274
Choke Cable Bracket & throttle spring bracket variations
22276.jpgAlbum 22276
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Choke_Cable"
This page has been accessed 16,111 times. This page was last modified 06:28, 9 March 2025. Content is available under Datsun 1200 Club.
