There is no page titled ":Haltech". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below 10 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- Fuel Injection (19606 bytes)
22: ...o tune your engine, no dyno needed. These include Haltech, Adaptronic, or MegaSquirt 2.
182: ...ftermarket ECU. Or universal Injector Bodies with HALtech ECU and GM sensors. Or fitting Ford TBI with Bosc... - EGI (26751 bytes)
306: ...e DYI ECU of choice. Others have successfully run Haltech, Wolftech, Link, or AEM ECUs with the EGI manifol... - MegaSquirt (8966 bytes)
47: # HALtech, Wolfe, and other aftermarket "custom" ECU system...
57: [[Haltech]] ECU - ECU (7624 bytes)
10: * Haltech - Oxygen Sensor (7106 bytes)
32: * Haltech can use it via the Haltech Wideband Controller add-on
42: * Haltech can use LSU4.2 with the add-on Haltech CAN wideband kit - L26 (5354 bytes)
60: * HALtech EFI controller - MR 1200 (3177 bytes)
14: * Haltech [[ECU]] - EGI Wiring (5246 bytes)
128: ...ng is information on Nissan ECUs. If using Motec, Haltech, etc. see their instructions. - Nissan Optical CAS (7489 bytes)
201: == Haltech ==
202: Newer model Haltech ECUs supports Nissan Optical CAS. - Crank Trigger (4324 bytes)
14: ...park-control capability, while MegaSquirt, recent Haltech, Wolf and most other populars ECUs do. They can a...
