Transmission Diagnoses
From Datsun 1200 Club
Categories: Diagnoses and Corrections | Transmission
Please add to these Transmission Diagnoses and Corrections based on your experience.
Difficulty Switching Gears
  • First gear won't go in if car rolling
    • By design: 1st gear is not sychro
  • Noise, trouble shifting into one specific gear
    • Bad synchro
    • Bad gear, perhaps chipped
Slips Out of Gear
Although rarely occuring this is one of the weak points of the 56- and 60- transmission designs.
  • Shifter mechanism
  • chipped gear
Noisy
Component Determination
Try to determine if it is a transmission or some other component:
  • Clutch pedal down, noise goes away. Clutch pedal up, noise starts
    • Transmission input shaft or counter gear
  • Noise only when clutch pedal depressed
  • Noise at any gear, at certain road speed
  • Vibration in any gear, at certain higher speed
  • Noise in a particular gear over a range of speed. No noise in lower or higher gear
    • Transmission
Potential Causes
  • Low on gearbox oil
    • Leak
    • Not filled with enough oil
    • Filled too full
  • Worn bearings (whine at high speed)
  • Bad bearings or bushing (knock at low speed)
  • Clunk - worn splines
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Transmission_Diagnoses"
This page has been accessed 1,438 times. This page was last modified 04:35, 12 April 2013. Content is available under Datsun 1200 Club.
