Main : Mechanical : Engine radiator and intercooler mounting
[<   Previous  2278  2279  2280  2281  2282  2283  2284  Next   >]
radiator and intercooler mountingPopular
Submitter1200_bruteMore Photos from 1200_brute   Last Update2006/9/24 1:20    Tell a friendTell a friend
Hits4360  Comments6    0.00 (0 votes)0.00 (0 votes)
different approach to the mounting of both the intercooler and radiator. also adds a lot more strength the the front end of the car :D
1200_brute
Posted: 2006/10/8 3:27  Updated: 2006/10/8 3:27
 Re: radiator and intercooler mounting
its a n14 pulsar radiator, just need to find some fans that are skinny enough to fit! Had some 10" but 10's werent big enough, then swapped em for 12's, they were too fat. still looking at the moment. i recon the air filter is gonna be tight also.
ANGE
Posted: 2006/10/8 9:15  Updated: 2006/10/8 9:15
that looks a lot more like an n13 radiator to me
1200_brute
Posted: 2006/10/10 14:32  Updated: 2006/10/10 14:32
ah n13 then,
thanks for pointing that out didnt mean to mislead anyone, my bad
Tom
1200_brute
Posted: 2006/9/24 2:14  Updated: 2006/9/24 2:14
has anyone done a similar set-up before?
or how has yours been done?
the most common ive seen is 2 brackets straight off the body near the bonnet latch
Tom
1200_brute
Posted: 2006/9/26 13:58  Updated: 2006/9/26 13:58
or we can all just sit there and be quiet :P
shaun
Posted: 2006/10/2 12:37  Updated: 2006/10/2 12:37
what sort of radiator is that
dattodude
Posted: 2006/10/2 12:47  Updated: 2006/10/2 12:47
Yeah man, that looks the goods. I agree that some structural strength across the front can't be a bad thing.
You can kind of see where mine goes, it's 10mm square tube running along the front. It's hidden up underneath the top panel.
ca18det_man
Posted: 2006/10/2 13:34  Updated: 2006/10/2 13:34
I have done simaller to my ca18 1200. I use a 20x20x3 SHS section welded into the front support panel with radiator & intercooler attatched to that. Stiffens the front end quite a bit after all that choping out
