Main : Members : datrat_dave New sleeve
[<   Previous  3  4  5  6  7  8  9  Next   >]
New sleeve
New sleevePopular
Submitterdatrat_daveMore Photos from datrat_dave   Last Update2006/9/28 9:02    Tell a friendTell a friend
Hits2573  Comments5    0.00 (0 votes)0.00 (0 votes)
Once again... Block was pressure and sonic tested whilst it was in this state. If this doesnt work, i give up on the A series!
datrat_dave
Posted: 2006/9/28 9:06  Updated: 2006/9/28 9:06
 Re: New sleeve
The crack in number 1 cylinder was about an inch and a half long, stretched down to the bottom of the bore.
Everything went A ok & test's came out ticks across the board after the new sleeve was fitted, labour parts & everything inclusive added up to $225.
Ok price i spose, pretty much a new engine again after the gave each cylinder a bore/hone & cleaned out all the rusty/gunk in the coolant holes...
A15 should be back in the ute by next week.
killer1200
Posted: 2006/9/28 10:20  Updated: 2006/9/28 10:20
 Re: New sleeve
Interesting honing job, but it might just be how the light is catching it.
datrat_dave
Posted: 2006/9/28 10:59  Updated: 2006/9/28 10:59
 Re: New sleeve
Just a flood light catching the deck... Its not out of spec dont worry.
sunny
Posted: 2006/9/28 14:07  Updated: 2006/9/28 14:07
 Re: New sleeve
was it machine honed ?
the cross hatching looks a little flat , but it could be the angle of the photo too
killer1200
Posted: 2006/9/28 14:59  Updated: 2006/9/28 14:59
 Re: New sleeve
Thats what I meant it should be at 45 degs crossing.
datrat_dave
Posted: 2006/10/3 10:40  Updated: 2006/10/3 10:40
 Re: New sleeve
Everything was done by machine, well im fairly sure as thats how they described it & how it came on the recipt...
I can get a better photo if you guys want it, its just that the block is on its side atm & it was late in the arvo with 2 floodlights reflecting from 2 different angles.
Oh thought i'd get the engine in by sunday but sure enough something else happened, we had MASSIVE winds last week & my dial indicator was sitting on the bench. Sure enough it falls off & the screen cracks & the pin falls off - great $60 down the drain
Cam timings getting done today.... I hate tassie sometimes
Dave
