Main : Mechanical : Engine dimlight's Z20E engine swap 4
[<   Previous  2787  2788  2789  2790  2791  2792  2793  Next   >]
dimlight's Z20E engine swap 4Popular
Submittertens_and_twentiesMore Photos from tens_and_twenties   Last Update2003/3/7 5:13    Tell a friendTell a friend
Hits6397  Comments13    0.00 (0 votes)0.00 (0 votes)
Overall right side.
Lobster
Posted: 2003/3/7 11:20  Updated: 2003/3/7 11:20
 Re: dimlight
Z18 is the one you are thinking of. It's the 1.8 litre version of this enigne with a turbo on it I believe.
I don't think that Australia got the z20 over here.
But not sure.
b310gx
Posted: 2003/3/7 11:53  Updated: 2003/3/7 11:53
 Re: dimlight
the z20 came in some navaras & some urvans here in oz.a bit agricultural & buzzy.but the z20e is obviously a passenger engine so probably a smoother motor.& a big motor with an auto is sometimes better than a manual,particularly as i seem to remember this is for someone's mother to drive.can do easier burnouts,too.tack it up.
dimlight65
Posted: 2003/3/7 15:18  Updated: 2003/3/7 15:18
 Re: dimlight
Spot on! This is the car I'm building for my mother. It is also the engine out of the Chickenhawk.
go_the_datto
Posted: 2003/3/8 4:33  Updated: 2003/3/8 4:33
 Re: dimlight
Hey very impressive keep working on it man.
Looks like they fit in not too badly
1200ute8u1
Posted: 2003/3/7 11:14  Updated: 2003/3/7 11:14
 Re: dimlight
did they make an engine called just a z20 or a z20 turbo cus i see them all the time in 1600 or its tha same pic but im sure it sais turbo on the top
D
Posted: 2003/3/9 10:09  Updated: 2003/3/9 10:09
From: under the Firmament LOL no twiglight effect BS
 Re: dimlight
Hey DD has anyone put a z24 and a turbo in any sunny or other small datto??
or a ca24 with twin cam head fromt he ca18 with a turbo?
tens_and_twenties
Posted: 2003/3/9 18:54  Updated: 2003/3/9 18:54
 Re: dimlight
Well, the Z20E only clears the hood by about 10-15cm in a 1200. Since the Z24 is nearly 20cm taller, it would be a tough fit in a 1200. I've seen several Z24's in 1600's (510's), even one with a turbo.
Maybe if you could find an Excellent hood?
Posted: 2003/3/9 19:23  Updated: 2003/3/9 19:23
 Re: dimlight
Who needs a hood?
Seriously, you could cut a hole in the hood/bonnet and put an aftermarket scoop over the hole. In any case, 2 liters ought to be enough to make that automatic a lot faster than your A12 with 4-speed.
I think the 2.5 from the new Sentra and Altima might be the ultimate way to go. It's as light as the CA18DE, but has more CCs than the heavy KA24.
tens_and_twenties
Posted: 2003/3/9 19:27  Updated: 2003/3/9 19:27
 Re: dimlight
This car is planned to be all stock on the outside, so no hood scoops allowed.
Personally I think it'll be faster than even a 1200 with an A14/5spd.
Should surprise more than a few with a stock appearance and 120-130hp+ under the hood.
tens_and_twenties
Posted: 2003/3/10 2:26  Updated: 2003/3/10 2:26
 Re: dimlight
What tranny to use, though? This engine isn't available RWD.
Posted: 2003/3/10 5:09  Updated: 2003/3/10 5:09
 Re: dimlight
What tranny, not sure. But as a replacement for the KA24, perhaps some will be coming. Also, perhaps it uses the same/similar trans to another engine series. Lots of questions for this new powerplant.
rgrinder
Posted: 2003/3/10 8:11  Updated: 2003/3/10 8:11
 Re: dimlight
hey Tens,
you misspoke, the Z24 is 20 MM taller, not 20 Cm taller, that's a difference of 180 MM. sorry to nit-pick.
for those who don't know, the "Z" series motors are basicly the "L" series leaned to the left instead of the right, with a cross flow head. here we got them as Z20, Z22, and Z24. for those who wish, the cylinder heads are interchangeable between the Z and the L series without much work.
other than the head , the other thing that needs a change is the timing cover.
the Z20, and Z22 use the L20 timing cover.
the Z24 is taller and doesn't have an equivilant L series counter part.
being as I have never seen one, I can only speculate as to which timing cover the Z18 would use, as the L16, and L18 is shorter than the L20.
could someone who has one make a measurement?
By the way, I have been told that even though the L series head is a non cross flow design, they flow much better than the Z series heads.
