Main : Mechanical : Brakes Landcruiser 4 spots with 13" wheel
[<   Previous  264  265  266  267  268  269  270  Next   >]
Landcruiser 4 spots with 13" wheelPopular
SubmitterR-fastmotorsportMore Photos from R-fastmotorsport   Last Update2006/11/4 6:17    Tell a friendTell a friend
Hits3847  Comments9    0.00 (0 votes)0.00 (0 votes)
Landcruiser 4 spot caliper on stanza hub with S13 rotor. Can fit my 13" wheels with good clearance - can't wait to try them out!!
dattoman_1000
Posted: 2006/11/4 8:02  Updated: 2006/11/4 8:02
 Re: Landcruiser 4 spots with 13" wheel
Heavy lil suckers
blofly
Posted: 2006/11/4 8:15  Updated: 2006/11/4 8:15
holy moly that will slow you up bloody good! I went for a ride in a VS commodore once with the same calipers and they felt awesome compared to the stock ones.
I see you have horizontal struts too
R-fastmotorsport
Posted: 2006/11/4 10:17  Updated: 2006/11/4 10:17
Hey dattoman,
everything is heavy to you 1000 blokes
They came up at the right price and they nearly fit(??) so away we go Use of 13" wheels is the bonus
Yeah Blofly, I hope they stop !!! And those horizontal struts are fairly rare - anyone can get the vertical ones
Cheers
R-fastmotorsport
Posted: 2006/11/23 10:42  Updated: 2006/11/23 10:42
UPDATE ....
Bedded in the new stoppers on Wednesday at Wakefield Park ....
ooooooohhhh baby - they stop now
All smiles after all the hard work, should have done it ages ago! Probably will get a tiny bit better with next outing
Cheers
picko
Posted: 2006/11/23 13:43  Updated: 2006/11/23 13:43
does anyone know what is involved in getting the s13 discs to fit the stanza stubs??
cheers
also what year landcruiser are those calipers off??
thanks again
PIGDOG
Posted: 2006/11/23 23:01  Updated: 2006/11/23 23:01
those calipers looks to be the staggered size piston ones(one big one small) so they should be off 60 series landcruisers
at a guess to get the disc to fit
-needs new holes drilled so it bolts on right
-centre bored out to the same size as the hub centre
-and i heard something about it needing to be machined smaller si its fits in the caliper???
R-fastmotorsport
Posted: 2006/11/25 3:38  Updated: 2006/11/25 3:38
Hey guys,
have a look at earlier post "Landcruiser 4 spots" - some info there.
Cheers
R-fastmotorsport
Posted: 2006/11/4 6:31  Updated: 2006/11/4 6:31
Almost ready Like all "bolt on" upgrades there was more to it than first thought - but nearing the end now! Many thanks to Dave at Autopro (you know who you are ) for all the endless product trials ....... I feel another upgrade comming your way soon Look out Benny boy .... look out And as for the Dog .... well .... he has to get close enough before he can offer any braking duel
Cheers
CA120Y
Posted: 2006/11/4 7:17  Updated: 2006/11/4 7:17
Quite a regular
Did those calipers bolt onto the original caliper mounts?? is the stock stub axle right for the s13 hub and rotors?? did you have to space anyhting?
thanks
R-fastmotorsport
Posted: 2006/11/4 10:12  Updated: 2006/11/4 10:12
CA120Y,
Yes, the calipers bolt on, didn't use a S13 hub so I don't know about compatability with stanza stub?
Be warned .... it is no 'bolt on' or 5 minute job. Caliper is shimmed about 1mm to acieve dead centre.
Cheers
