Main : Mechanical : Brakes Landcruiser 4 spots
[<   Previous  263  264  265  266  267  268  269  Next   >]
Landcruiser 4 spots
Landcruiser 4 spotsPopular
SubmitterR-fastmotorsportMore Photos from R-fastmotorsport   Last Update2006/11/4 6:20    Tell a friendTell a friend
Hits7941  Comments7    0.00 (0 votes)0.00 (0 votes)
Another shot of the upgrade without the wheel. A bit of machining here and there for clearances but not impossible if you are able to use a lathe.
PIGDOG
Posted: 2006/11/5 1:19  Updated: 2006/11/5 1:19
 Re: Landcruiser 4 spots
are they just solid 200b or 240k discs?
what did you have to do to get it all to fit, mine were pretty good
just needed to space the caliper out a bit
1200rallycar
Posted: 2006/11/5 5:25  Updated: 2006/11/5 5:25
interested in disc also, mine is a pintara vented disc, would be a pity to still be using solids after fitting such big calipers
edit: oh it says silvia disc on other pic, thats good, what work had to be done to the disc?
R-fastmotorsport
Posted: 2006/11/5 8:22  Updated: 2006/11/5 8:22
Hey guys,
yes S13 rotor with a few mods You have to bore the centre of the rotor to fit the stanza hub through and drill for the hub bolts. A small amount has to be taken from the rotor hub outer dia to clear the caliper, and the caliper has had some reshaping on the outer face to clear. Trial fitting and refitting was wearing a bit thin
Also had to reshape one pad each side ....... but it will all be worth it
Cheers
PIGDOG
Posted: 2006/11/5 9:10  Updated: 2006/11/5 9:10
right, i might have to hunt down a vented disc, kinda over trying to get the torrago disc to fit
dattoman_1000
Posted: 2006/11/5 9:58  Updated: 2006/11/5 9:58
S13 SR20det disc = DBA919
U12 FWD Pintara disc = DBA903
DBA919 = DBA903
DBA903 = cheaper
Trade secret......... shhhhh
PIGDOG
Posted: 2006/11/5 10:00  Updated: 2006/11/5 10:00
so how much would i be looking at for a pair of them, the cheap ones
Posted: 2016/6/5 23:57  Updated: 2016/6/6 11:48
DBA919 = DBA903
DBA903 = cheaper
Per DBA catalogue, U12 FWD Pintara disc = DBA617 or DBA609
* DBA617 is 257mm rotor (U12 Pintara)
* DBA609 is 250mm rotor (U12 Pintara Executive Sedan)
DBA list DBA903 which is 280 mm disc
The disc in the photo appear to be S13 250 mm disc
See S13 Brakes
