Main : Racing : Track Worsel's 1200 racecar
[<   Previous  157  158  159  160  161  162  163  Next   >]
Worsel's 1200 racecarPopular
SubmitterworselMore Photos from worsel   Last Update2007/1/3 1:58    Tell a friendTell a friend
Hits3745  Comments9    0.00 (0 votes)0.00 (0 votes)
1200 racecar, CA18det, silvia 5 speed, H165 locked rear with 4 link & watts linkage, 300zx struts & 4 pots front, bluebird rear disks,
worsel
Posted: 2007/6/1 21:01  Updated: 2007/6/1 21:01
 Re: Worsel
Ok guys, car is 1972 4 door. CA18DET with race cams, GT2871R turbo, S14 Silvia 5 speed with .864 5th gear ratio to give 139m.p.h at end of our straight. 15x205/50, 4.11 ratio H165 locked rear. Skyline GTR 4 pot fronts, U12 Bluebird disc rears with bias in car. Rear doors removed & just outer skins to save weight. Fr doors lightened. Cage thru to strut towers. 300zx struts, double anti roll bar fr. 4 link rear & watts linkage to locked H165. Lexan windows except fr screen. Fr bumper is Nissan Primera, has undertray back to fr wheels for downforce & front lip. Currently with new motor waiting for adj cam gears to be fitted, yet to bed in. Last motor threw out rod @ about 7,800 in 5th which left hole in block & 2 holes in new sump as well as a multi piece rod & piston. It breaks axles & has broken 2 gearboxes also. Yep, as the sgn on the back says "shes a wild ride".
worsel
Posted: 2007/1/4 4:11  Updated: 2007/1/4 4:11
 Re: Worsel
Yep she's a "budget" 2 door, a 4 door with no rear doors, just outer skins to save weight. L/H was replaced with a hand rolled skin after an impossible late braking attempt by a Commodore a few years ago, thats why l/h side looks like a 2 door
TnPshow
Posted: 2007/1/3 9:21  Updated: 2007/1/3 9:21
 Re: Worsel
Damn that looks tough!
Nice work!
Posted: 2007/1/4 2:51  Updated: 2007/1/4 2:51
 Re: Worsel
Is that a tudor 4-dr sedan?
jaimecidpedro
Posted: 2007/1/4 5:37  Updated: 2007/1/4 5:37
 Re: Worsel
Looks like it can handle cornering with its eyes closed
TnPshow
Posted: 2007/1/4 9:40  Updated: 2007/1/4 9:40
 Re: Worsel
I really like the (4)2 door look!
Ianey
Posted: 2007/5/31 21:38  Updated: 2007/5/31 21:38
 Re: Worsel
Looks really tough!
I reckon a 4 door, without the rear doors
(similar to this) but with longer front doors would look really good.
cheers
datsun_guy
Posted: 2007/5/31 21:46  Updated: 2007/5/31 21:46
 Re: Worsel
you got a front pic i like the look of that bumper whats it off?
PIGDOG
Posted: 2007/5/31 23:50  Updated: 2007/5/31 23:50
 Re: Worsel
Ianey you mean a 2 door sedan
Posted: 2007/6/1 18:33  Updated: 2007/6/1 18:33
 Re: Worsel
Yes, 2-dr sedans have longer doors -- the same length as the Coupe (they use the same door lower half as the coupe).
The practical difference between a "tudor" and a factory 2-dr (other than door length) is the shape of the rear side glass. This one here looks more like Datsun 510 (1600) glass. The 2-dr 1200 has a rounded instead of sharp shape.
I think I like this glass shape better than the real 2-dr.
Playgrl
Ianey
Posted: 2007/6/1 21:48  Updated: 2007/6/1 21:48
 Re: Worsel
I always knew those datsun engineers and I had something in common.
