Main : Members : PIGDOG new brakes
[<   Previous  106  107  108  109  110  111  112  Next   >]
new brakes
new brakesPopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2007/1/12 6:14    Tell a friendTell a friend
Hits2062  Comments8    0.00 (0 votes)0.00 (0 votes)
landcruiser calipers and camry discs fitted to the car
need to add a different colour to the calipers so they dont look so red
cheater_5
Posted: 2007/1/12 7:44  Updated: 2007/1/12 7:44
 Re: new brakes
paint the letters on them black.
Looks goo btw.
PIGDOG
Posted: 2007/1/12 8:12  Updated: 2007/1/12 8:12
 Re: new brakes
thanks guys, i was thinking of painting the letters (not that they really say anything interesting though) might wait till the red have fully cured so i can clean the black paint without smudging the red
the paint should last a while, theres a fair coating on there, over a whole millimetre of paint
havnt tested the brakes yet as there is a corolla stopping me from geting out of the shed, but they should stop it well.....even better when the R31 rears aer in there as well
Tyrie
Posted: 2007/1/14 10:15  Updated: 2007/1/14 10:15
 Re: new brakes
how thick is the camry rotor? Also what pads are you using?
Posted: 2007/5/8 16:01  Updated: 2007/5/8 16:01
Not too shy to talk
 Re: new brakes
Hopefully the rotor is a 732, 25mm thick.
13's go over this setup?
Tyrie
Posted: 2007/5/8 16:15  Updated: 2007/5/8 16:15
 Re: new brakes
that looks like a S12+8 caliper, which might not fit over a 25mm rotor, I've got them on 250mmx20mm magna rotors and they will fit under a 13" alloy with minimal grinding, no chance under a 13" steelie
Daveman
Posted: 2007/5/8 17:09  Updated: 2007/5/8 17:09
 Re: new brakes
What model camry rotors are they? and are they any easier or harder to use than the S13 rotors?
short-coupe
Posted: 2007/5/8 18:17  Updated: 2007/5/8 18:17
 Re: new brakes
what struts did u use?
PIGDOG
Posted: 2007/6/7 6:27  Updated: 2007/6/7 6:27
 Re: new brakes
discs are off an 88 model camry, 255x 22mm but the thicknes was machined down to 20mm
probably just as easy to use the s13 discs
with these you need a spacer to get the right offset and one of the new holes that needs to be drilled ends up half in and half out of one of the original ones
with the s13 discs i think you need to modify the caliper a bit to fit
they are 200b struts, same brake arrangement as stanza
WhiteSedan
Posted: 2007/1/12 6:30  Updated: 2007/1/12 6:30
 Re: new brakes
Good work PIGDOG, they should stop the beast nicely! They wont look so red after a few hard brakings.
