Main : Mechanical : Brakes SILVIA DISC BRAKE CONVERSION 3
[<   Previous  253  254  255  256  257  258  259  Next   >]
SILVIA DISC BRAKE CONVERSION 3Popular
SubmitterBUNDY351More Photos from BUNDY351   Last Update2007/2/8 2:59    Tell a friendTell a friend
Hits4481  Comments23    0.00 (0 votes)0.00 (0 votes)
What the finished product looks like.  Note that I now have the callipers towards the front of the car.  All I did was swap the struts and calipers from left to right hand sides.  Kev says this aids with clearing of steering components
estyre
Posted: 2009/10/21 9:41  Updated: 2009/10/21 9:41
 Re: SILVIA DISC BRAKE CONVERSION 3
hey can you rego a 1200 with this setup or do you need an engineer to sign it off and stress test and xray the bracket to pass rego and all that crap
and wont the whole thing flex when under hard braking because of the extra leverage and stronger caliper
crzy_1200_ute
Posted: 2007/9/30 9:22  Updated: 2007/9/30 9:22
when using the 120y strut are people using the 1200 tops or the 120y top hats?
cheers, Ben
frankthedolphintrainer
Posted: 2007/9/30 11:50  Updated: 2007/9/30 11:50
hey i just relised you sprayed your guards, sweet love it, ill have to get you to help me do it to the new ute
crzy_1200_ute
Posted: 2007/9/30 13:15  Updated: 2007/9/30 13:15
cheers, Ben
ANGE
Posted: 2007/9/30 13:17  Updated: 2007/9/30 13:17
1200
crzy_1200_ute
Posted: 2007/9/30 13:28  Updated: 2007/9/30 13:28
i seen a pic on here before and they used the 120y tops hmm :(
opps i drilled the hole out the bit biigger OPPSS
PIGDOG
Posted: 2007/9/30 13:31  Updated: 2007/9/30 13:31
just looking at these, there would be about an 8mm increase in track either side would there not(thickness of disc flange bit)
and with stanza struts and what not you get 20mm a side?? but with late ute or 120y balljoints that goes back down to 10mm a side....so near same track by my calculations
so basically, go team big struts
EDIT, if you drilled the top bolt holes out(i thought 120y tops had the same studs) then just get some stanza or sunny tops as they use bigger studs than stock but are the same design top, might have to keep drilling/filing though
ANGE
Posted: 2007/9/30 13:32  Updated: 2007/9/30 13:32
i think its actually 7mm
and about 35kg lighter
PIGDOG
Posted: 2007/9/30 13:36  Updated: 2007/9/30 13:36
thats it, get the scales out
maybe 35kg heavier if you have my fat arse brakes on there compared to stock 120y brakes....but this is fair as i could probably melt the 120y brakes down as use them as pads in mine
ANGE
Posted: 2007/9/30 13:47  Updated: 2007/9/30 13:47
forget the scales
id like to see if your car actually even stops well with your ginormous brakes.
would take some effort to pull up those big front struts and L donk
PIGDOG
Posted: 2007/9/30 13:56  Updated: 2007/9/30 13:56
you forgot the huge R31 diff
if it wasnt for that i could do front flips
ANGE
Posted: 2007/9/30 13:59  Updated: 2007/9/30 13:59
i dunno about flipping it,
but pulling the rear wheels up when you come to a stop could be pretty cool
PIGDOG
Posted: 2007/9/30 14:17  Updated: 2007/9/30 14:17
hmmm maybe if i fited some really really wide slicks on the front it might have enough grip
but if i really wanted that i could just ride a bike
maybe you should whack some GTR brakes on the front of yours to get that same stopping experience i get, seems as you have the brackets to fit them and all
GIDZ
Posted: 2007/6/16 6:51  Updated: 2007/6/16 6:51
what size rims fit this setup
PIGDOG
Posted: 2007/6/16 7:05  Updated: 2007/6/16 7:05
i was going to say....do you think the brakes i got today are overkill
i guess i am weighed down by the heavy L series and R31 diff, so i need all the extra stopping power coz my cars so overweight
2QK4U
Posted: 2007/6/16 8:11  Updated: 2007/6/16 8:11
hey if you can do it why not!! i just found the Sr sylvia setup to be best for my needs and would be ample for my car. for you guys it might be different. but dam GTR brakes with Nissan emblem and 4 spots would look soo good under a 13- 14inch rim ahahah.
crzy_1200_ute
Posted: 2007/6/16 6:45  Updated: 2007/6/16 6:45
as i meant was.. like most hubs have like a little screw holding the rotor to the hub so the rotor doesnt have any move ment in it..
Chassis_slappin_1200
Posted: 2007/2/8 17:24  Updated: 2007/2/8 17:24
From: whakatane, but most of the time canterbury NZ
Are these 1200 struts?
Tyrie
Posted: 2007/2/8 17:30  Updated: 2007/2/8 17:30
they're made for 120y struts IIRC
they look good, can you use the same bracket to mount nissan 4pots?
crzy_1200_ute
Posted: 2007/6/16 4:50  Updated: 2007/6/16 4:50
Hey...
wondering wat holds the silvia rotor to the hub??
or does the wheel just hold the rotor on straight??
PIGDOG
Posted: 2007/6/16 6:37  Updated: 2007/6/16 6:37
hmmm tyrie i was thinking the same thing
people who have done this should be able to go find some 300zx calipers and 280x30mm rotors and have massive brakes
seems as they go straight onto silvias
edit: yes the wheel holds the disc on
2QK4U
Posted: 2007/6/16 6:44  Updated: 2007/6/16 6:44
Yes nissan 4 pots share the same caliper bolt spacing, but the disc needs to be drilled to 4 stud, and finding a 114.3 4 stud wheel that clears a caliper that size is very hard. off set are stupid. and really the SR syliva brakes are ample, 4 spots on a 600kg car is abit over kill wouldnt you think? adavnatge is though that U13 bluebird calipers a identical to sylvia in size and caliper bolt spacing but are twin spots, and have a much thicker disc.
Tyrie
Posted: 2007/6/16 6:49  Updated: 2007/6/16 6:49
yeh for sure, but on our 800-1000kg dattos they are the shiz
