Main : Mechanical : Engine Blower 3
[<   Previous  2266  2267  2268  2269  2270  2271  2272  Next   >]
Blower 3
Blower 3Popular
SubmitterGrunterhunterMore Photos from Grunterhunter   Last Update2007/2/19 18:36    Tell a friendTell a friend
Hits3042  Comments6    0.00 (0 votes)0.00 (0 votes)
Left side
DatsunDrifter1
Posted: 2007/2/20 23:56  Updated: 2007/2/20 23:56
 Re: Blower 3
That's one mean looking machine!!
jaimecidpedro
Posted: 2007/2/21 0:26  Updated: 2007/2/21 0:26
 Re: Blower 3
What a ride.....I can only wonder......
ZZZZZZZZZZzzzzzzzzzzzzzzzzzzzzzzzz!!!
Grunterhunter
Posted: 2007/2/22 22:20  Updated: 2007/2/22 22:20
 Re: Blower 3
Yup, torque like a turbo diesel.You really notice the extra punch down low. My girlfriend's nissan micra (approx 950kg) broke down the other day & i had to tow it up a reasonably steep hill (probably 1 in 5 incline)- Half throttle, 3-4 psi of boost at 2000 rpm in 4th and it just chugged its way up, happy as larry
A14force
Posted: 2007/2/20 2:46  Updated: 2007/2/20 2:46
 Re: Blower 3
Looking nice!
find a dyno. and get us some dyno figures!
Grunterhunter
Posted: 2007/2/20 23:41  Updated: 2007/2/20 23:41
 Re: Blower 3
Clearance is fine all round...... or would be with a standard ramflow for a dgv. the filter that's on there was originally for the stock carb, & (to cut a long story short) I had to hack it and add an adapter that is about an inch high (bits of filing cabinet rail, welded together). So the overall height is marginal & I have a little bump in the bonnet, but tyhat is only cos the air filter is an inch higher than it was supposed to be.
I will try and get some dyno or 1/4 mile times out of it soon. At the moment I am trying to work out how to rig up a home made water meth injection. Thinking of running a pressure vessel (old gas cylinder or the like) with a 12v tyre pump attached running 60-100psi, then rig up an electric switch from the throttle to actuate. needs a bit more thought & research tho.
TnPshow
Posted: 2007/2/19 21:13  Updated: 2007/2/19 21:13
 Re: Blower 3
nice install!
What's underbonnet clearance like? Looks like a fair bit...
