Main : Members : PIGDOG V6 IRS ute, front camber
[<   Previous  99  100  101  102  103  104  105  Next   >]
V6 IRS ute, front camberPopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2007/3/12 19:02    Tell a friendTell a friend
Hits2289  Comments10    0.00 (0 votes)0.00 (0 votes)
been playing around with the front end
ended up using a combo of 200b and 1200 lower arms and bluebird struts with r31 brakes
lower control arms are 20mm longer than stanza ones and the strut tower will be raised and moved inwards for more camber and travel
but this pic gives an idea of how it will look
Burke_a_lot
Posted: 2007/3/13 6:14  Updated: 2007/3/13 6:14
 Re: V6 IRS ute, front camber
good luck
keep with it looking great
PIGDOG
Posted: 2007/3/13 6:16  Updated: 2007/3/13 6:16
i dont need luck, just more cutting discs
datrat_dave
Posted: 2007/3/15 1:57  Updated: 2007/3/15 1:57
Im heading down torquay way next weekend i think, i really need to see this beast it looks so uglily pretty (if thats a word!)
Reckon you'll be ready for datnats dude?
PIGDOG
Posted: 2007/3/15 3:38  Updated: 2007/3/15 3:38
it might be in some state of movement by datnats, but it wont be there unfortunatly
if you really want to come see it thats fine
oh and the word you were looking for....beast
WhiteSedan
Posted: 2007/3/12 20:07  Updated: 2007/3/12 20:07
How do the 200b lower arms bolt up and what balljoint did you use mate? Thats going to be one hell of a mod to the strut tower.
PIGDOG
Posted: 2007/3/12 20:18  Updated: 2007/3/12 20:18
bolt up, well it requires an angle grinder and a welder
uses 200b balljoints and steering arms
200b control arms in too long and to small where it bolts onto the crossmember, so i cut it down and welded the original 1200 control arm end to it
yet to figure out castor arms though
strut tower is moving in 1 to 2 inches, and up as far as it can go. made some strut tops up that are flat so it can go nice and high and i can drill the hole to the side for even more camber
WhiteSedan
Posted: 2007/3/12 20:23  Updated: 2007/3/12 20:23
Thats the sort of bolt up im used to as well!
How much camber are you chasing? You'll have like 7
PIGDOG
Posted: 2007/3/12 20:29  Updated: 2007/3/12 20:29
haha yeah the grinder and welder mods are all this ute is used to
im after as much camber as i can get, how it is now the strut is on the biggest angle the standard size springs will allow in the struts tower
pretty much on par with the rear at the moment with camber
the IRS is almost done, gotta finish running the chassis rail through the car (joining to the chassis rails in the engine bay) then i just have to make a brace up to somewhere near the back window height
then just little things like spring mounts and shocks ect
crossmembers done aswell, so once the front ends finished the engine will go back in, gearbox crossmember will be made and then wiring and tunnel making will start.....fun fun fun
dazzasute
Posted: 2007/3/12 22:20  Updated: 2007/3/12 22:20
why are you running that much camber? I cant see any way that it would improve performance unless your driving inside a very large pipe...
PIGDOG
Posted: 2007/3/13 6:09  Updated: 2007/3/13 6:09
coz im going pipe racing
improved looks, not performance
i can always wind the camber back in if i want
besides...it doesnt seem to hurt v8 supercars to have that much camber
