Main : Members : PIGDOG V6 IRS ute
[<   Previous  96  97  98  99  100  101  102  Next   >]
V6 IRS ute
V6 IRS utePopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2007/4/16 6:06    Tell a friendTell a friend
Hits3187  Comments13    0.00 (0 votes)0.00 (0 votes)
dodgy camera phone pic, but gives some idea of how the front looks
cheater_5
Posted: 2007/4/16 9:23  Updated: 2007/4/16 9:23
 Re: V6 IRS ute
aha thats got to be the most camber i've ever seen on a car at the front. nice work lol.
Dont likewhat everyone else is doing???
Screw them
PIGDOG
Posted: 2007/4/16 10:50  Updated: 2007/4/16 10:50
 Re: V6 IRS ute
haha yeah its got more camber than what these pics make it out to be
makes the back look like it doesnt have camber at all
kululadotgroen
Posted: 2007/4/17 10:26  Updated: 2007/4/17 10:26
 Re: V6 IRS ute
You must watch out for that lovebus, it will corrupt your UTE's mind and it'll become a VSEX powered lounger...*hehehe*
PIGDOG
Posted: 2007/4/17 12:20  Updated: 2007/4/17 12:20
 Re: V6 IRS ute
nah that lovebus hasnt had loving for a very very long time.....it wont be able to corrupt anything
WhiteSedan
Posted: 2007/4/17 12:22  Updated: 2007/4/17 12:22
 Re: V6 IRS ute
So its all coming together now Pigdog? How did the strut towers go?
PIGDOG
Posted: 2007/4/17 12:30  Updated: 2007/4/17 12:30
 Re: V6 IRS ute
yeah its getting there, didnt get as much work done over easter as i would have liked but the front ends all kinda finished on it
just gotta get some more RHS to finish the chassis rails so i can make gearbox crossmember
spent most of the time on the sedan, got the R31 diff in, so now have discs all round and a 22mm rear swaybar.....yes its big
came out way under budget on the diff though as i only had to change the flange on my h165 one and it bolted straight up(sorta)
WhiteSedan
Posted: 2007/4/17 12:44  Updated: 2007/4/17 12:44
 Re: V6 IRS ute
Im gonna start doing a disc conversion, Ive got R31 rear discs and backing plates, S3 TRX calipers without h/brake stuff all going onto a locked Ke55 diff.
PIGDOG
Posted: 2007/4/17 13:03  Updated: 2007/4/17 13:03
 Re: V6 IRS ute
geez, if you were going to use a h165 i could have swaped backing plates with you, mine are all setup for the datsun diffs
the bluebird calipers would be the same as commo ones then i guess.....think you need the skyline caliper bracket so that they will go onto the caliper mount
WhiteSedan
Posted: 2007/4/17 13:12  Updated: 2007/4/17 13:12
 Re: V6 IRS ute
I was almost going to use a H165 from a stanza to get some more width to fill the flares, but the corolla diff sits on the leafs nice so thats easier its a bit wider than the standard dato diff too, just have to work out tailshaft, Im hoping the dato borgy tailshaft fits the corolla borgy diff.
The TRX Calipers fit on the R31 bracket no worries, all I have to do is get the spacing right so it all lines up.
L18_B110
Posted: 2007/4/17 14:08  Updated: 2007/4/17 14:08
 Re: V6 IRS ute
use the datto borg warner flange on the corolla borg warner diff and bob's your uncle
WhiteSedan
Posted: 2007/4/17 14:15  Updated: 2007/4/17 14:15
 Re: V6 IRS ute
Cool, Im using an auto 1200 borg warner tailshaft at the moment so It all should bolt in as long as the nose of the corolla diff isnt longer than the datsun one.
PIGDOG
Posted: 2007/4/18 14:30  Updated: 2007/4/18 14:30
 Re: V6 IRS ute
it will be, as the 1200s have the small BW and the KE30s onwards have the bigger one
well id assume the bigger one would be longer...think they are different flanges from small to big aswell, might take some measurements tomorrow of the few i have
stanza tailshaft works well as a start when cutting one down
PIGDOG
Posted: 2007/4/16 6:14  Updated: 2007/4/16 6:14
 Re: V6 IRS ute
