Main : Members : PIGDOG r31 diff
[<   Previous  94  95  96  97  98  99  100  Next   >]
r31 diff
r31 diffPopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2007/5/3 4:51    Tell a friendTell a friend
Hits3549  Comments16    0.00 (0 votes)0.00 (0 votes)
sitting nicely under my sedan
cheater_5
Posted: 2007/5/4 20:40  Updated: 2007/5/4 20:40
 Re: r31 diff
any idea how much torque these things can handle ?
u rekon it could with stand a ca18det with small mods? just be interesting to know for future
PIGDOG
Posted: 2007/5/4 20:57  Updated: 2007/5/4 20:57
 Re: r31 diff
these diffs seem to stand upto the torque of a commodore 5 litre with ease....so i dont really think the torque of a CA would bother it
dont really know about the drums actually, as they would be 5 stud if they were vl....id got get some r31 disks from the wreckers and see how the fit up(where the caliper ends up any way)
Tyrie
Posted: 2007/5/4 21:06  Updated: 2007/5/4 21:06
 Re: r31 diff
theres 9second VLs using these diffs, they should be strong enough
cheater_5
Posted: 2007/5/5 12:05  Updated: 2007/5/5 12:05
 Re: r31 diff
lol thats good.
cheater_5
Posted: 2007/5/3 21:15  Updated: 2007/5/3 21:15
 Re: r31 diff
are those standard rear disks on the r31 diff and what you rekon the minimum wheel dia is for clearance??
looks sooo good in there
PIGDOG
Posted: 2007/5/3 21:17  Updated: 2007/5/3 21:17
 Re: r31 diff
3.7 soon to be spooled centre....till i aquire an LSD
think the smallest i could fit over the rear discs was 14s, and yes they are just standard r31 rears
kegs
Posted: 2007/5/3 22:12  Updated: 2007/5/3 22:12
 Re: r31 diff
can i ask what brakes they are ? mine came with stock drums maybe this that u have is an easy conversion. wish i had disc's thatd be real nice
Tyrie
Posted: 2007/5/3 23:25  Updated: 2007/5/3 23:25
 Re: r31 diff
3.7?? man go 4.1 or 4.4 even, make it fun! I'm changing mine from 3.9 to 4.11 to get a bit more out of it.
Daveman
Posted: 2007/5/4 3:56  Updated: 2007/5/4 3:56
 Re: r31 diff
I have a 4.1 in my skyline diff and I'm in the process of looking for a lower ratio.
It screams at nearly 4000rpm on at 100kmh.
4.4 would would be ridiculous, I can already take off in 2nd gear on hills with the 4.1. You may as well take 1st gear out with a 4.4
PIGDOG
Posted: 2007/5/4 17:51  Updated: 2007/5/4 17:51
 Re: r31 diff
nah it already sits on 3 grand at 100kph...and with the l20b only reving to about 5 something stock
not really wanting any lower gearing, ill just find some money and get more power to make it interesting
kegs: they are just standard r31 skyline brakes...dont see why you would actually have an r31 diff without them, unless its a vl diff(in which case you might have to redrill the caliper bracket to get the caliper in a good spot) but im pretty sure all r31s, both skyline and pintaras came with rear discs
kegs
Posted: 2007/5/4 18:55  Updated: 2007/5/4 18:55
 Re: r31 diff
mine is silhouette std lsd even has the tag but maybe they used the brakes off a vl i dunno its got huge drums that work well
Dat50
Posted: 2007/5/3 13:09  Updated: 2007/5/3 13:09
Not too shy to talk
 Re: r31 diff
Whats the swaybar off?
Is it custom made?
Also the shocks look like upside down ones?
Are the adjustable?
Very nice conversion overall - love it!
Cheers Dat50
Tyrie
Posted: 2007/5/3 16:09  Updated: 2007/5/3 16:09
 Re: r31 diff
hmmm I like that swaybay, maybe a little thick though?
edit: how does the front of the caltrac? system mount up? I'd like that too
Daveman
Posted: 2007/5/3 16:28  Updated: 2007/5/3 16:28
 Re: r31 diff
is that just an R31 rear swaybar?
How do you plan to mount the ends to the body?
PIGDOG
Posted: 2007/5/3 19:11  Updated: 2007/5/3 19:11
 Re: r31 diff
width is 20mm wider than standard, which sits trx rims nicely till you lower the rear as much as i did (wheels scrub on the door seal groove thing
swaybar is an almost stock ea falcon item, had to bend the ends up so that the sway bar would be directly above the diff, its 22m which is probably just a tad big, but it went in so damn easy that i just couldnt resist....if i was to get one made id most likely not have it go over the diff as there isnt a great deal of clearance how it is
and i just cut the falcon mounts off the body and they fit nicely on the inside of the chassis rails....to easy really, ill post up a pic if i have one
shocks are upside down non adjustable torago items that as really firm compared to the standard shocks
and the front of the traction bars....ill find a pic, its just a pair of spring shackles welded to the ontside of the front spring hanger
PIGDOG
Posted: 2007/5/3 19:25  Updated: 2007/5/3 19:25
 Re: r31 diff
traction bar mount
and sorta showing the front swaybar mount
ANGE
Posted: 2007/5/3 20:51  Updated: 2007/5/3 20:51
 Re: r31 diff
looks great!
what ratio? lsd?
cheater_5
Posted: 2007/5/3 11:37  Updated: 2007/5/3 11:37
 Re: r31 diff
whats the width like on this thing?
