Main : Mechanical : Suspension Datsun 1000 Front suspension parts
[<   Previous  366  367  368  369  370  371  372  Next   >]
Datsun 1000 Front suspension partsPopular
Submitterqik1000More Photos from qik1000   Last Update2007/4/22 12:05    Tell a friendTell a friend
Hits9319  Comments14    0.00 (0 votes)0.00 (0 votes)
Heres my 1000 front end...all shined up.
kululadotgroen
Posted: 2007/4/22 19:28  Updated: 2007/4/22 19:28
 Re: Datsun 1000 Front suspension parts
I don't know why, but looking at this pic, I think like the 1000 suspension more than the 1200's...
beattie
Posted: 2007/4/22 21:33  Updated: 2007/4/22 21:33
Thats because its better
I see new upper ball joints... you bastard! Did you fork out for genuines or find some a/m items? I would love to do this, maybe when i pull the leaf out to get reset i will.
qik1000
Posted: 2007/4/22 12:07  Updated: 2007/4/22 12:07
Ianey
Posted: 2007/4/22 12:11  Updated: 2007/4/22 12:11
Looking great! Have you replaced all your bushes, etc? Used any/ many rose joints? Ball joints?
Cheers!
matbighat
Posted: 2007/4/22 21:45  Updated: 2007/4/22 21:45
by all accounts this front end is superior to a macpherson strut design, for track use at least ...
TnPshow
Posted: 2007/4/22 22:09  Updated: 2007/4/22 22:09
Hmmm nice! Mine will be like this soon - I have finished collecting bits except for the drag link - did you have it re-manufactured or did you actually get a new one?
Beattie - watch ebay - a NOS pair of upper BJs went for about $35 a couple of weeks ago...
D
Posted: 2007/4/22 22:20  Updated: 2007/4/22 22:20
From: under the Firmament LOL no twiglight effect BS
which urethane bushes are they like which model?
Also the engine mounts are for a later a series?
dattoman_1000
Posted: 2007/4/22 23:07  Updated: 2007/4/22 23:07
Yeah I got one of the 2 pairs of balljoints off ebay :)
His tierod ends looks alittle different to mine. I know there were 2 types
That would look so much better with disc brakes and coilovers
Dodgeman
Posted: 2007/4/23 0:00  Updated: 2007/4/23 0:00
Disc brakes, ... agreed, but coilovers? Not needed. Carefull prep of the leaf spring & good shocks will be all that is required.
Lowering can also be done in moderation for free & still be completely legal without unsafe modifications to the spring stack or any reduction in suspension travel. It's the headlight height that limits the minimum ride height from a legal perspective.
The B10 family of fine cars, .... perfection achieved.
qik1000
Posted: 2007/4/23 2:04  Updated: 2007/4/23 2:04
The drag links are original. I just cleaned prepared and painted them. The balljoints are all new - I tried everywhere including ebay and this site for months and got nowhere with the uppers till I tried a knowledgeable 19yo guy behind the counter at Repco. Their rare-spare devision has them. The lower bjs are new as well.
The bushes are new. I used datsun 1200 lower control arm bushes on my upper control arms but I had to enlarge to inner hole to about 14mm diamater. I tried several methods to do this as it is F A R harder than it sounds. I froze the bush, inside the old rubber housing, in the freezer then drilled them with a blade bit in an electric drill at maximum rpm. The lower bushes are from a Ford Transit van rear leaf spring shackle, and I reduced the thickenss of the flange on a belt sander.
TnPshow
Posted: 2007/4/23 2:24  Updated: 2007/4/23 2:24
Cool thanks for the info.
Topgear had his draglink 'reconditioned' by a guy here in Adelaide who can inject some sort of plastic into the join thus stiffening them up.
Not 100% sure how it works but I've got his number when it comes time to do it.
..Actually I need another drag-link. One that's straight preferably...
D
Posted: 2007/4/23 2:47  Updated: 2007/4/23 2:47
Excellent info on the bushes!! are the engine mounts custom to suit the later A?
Dattoman 1000
Ian boettcher has the coil over kits available on the 2nd page and also the adjustable rear leaf slider.
I still wouldnt mind coilovers for taller engine setups and allowing a different crossmember or square tubing.
http://www.iboettcher.com.au/springs.pdf
Also the universal "cage support shock mount" is available here
http://www.iboettcher.com.au/img/amcaad2lg.gif
qik1000
Posted: 2007/4/23 5:23  Updated: 2007/4/23 5:23
D, the cross member is unmodified, so its to suit an A10 or early A12. We have an A15 in the race car. It has a custom bracket between the cross member and the engine. The rules of our catagory state that the cross member must remain unmodified. It was also possible to move the engine back hard up against the firewall.
combo1000
Posted: 2011/6/25 9:14  Updated: 2011/6/25 9:14
hi guys just after some info on the suspension what model ford transit van bushs did you use cheers
