Main : Mechanical : Suspension Leaf springs
[<   Previous  367  368  369  370  371  372  373  Next   >]
Leaf springs
Leaf springsPopular
SubmitterTyrieMore Photos from Tyrie   Last Update2007/4/2 18:21    Tell a friendTell a friend
Hits5386  Comments10    0.00 (0 votes)0.00 (0 votes)
Is this safe?
e_pirate1337
Posted: 2009/8/17 2:09  Updated: 2009/8/17 2:09
Quite a regular
 Re: Leaf springs
nice i might be doing this soon
Dodgeman
Posted: 2007/4/2 20:28  Updated: 2007/4/2 20:28
 Re: Leaf springs
What is now the second leaf is unsupported at the halfway point between the end of the short bottom leaf & the end of the [new] second leaf.
Check the setup on the unmodified spring.
Reputable spring works heat the leaves in a forge from memory as the oxy torch tends to be too hot & too localised. The forge temperature is more readily controlled & it heats the whole thing, thereby relieving local stresses.
They probably heat them in an oven these days for all I know, ... & you know, that proper resetting is really the right way to go.
Tyrie
Posted: 2007/4/2 22:04  Updated: 2007/4/2 22:04
 Re: Leaf springs
of course, but I'm not paying to get that done. This only took an hour to do and (hopefully) wont fail
PIGDOG
Posted: 2007/4/3 17:33  Updated: 2007/4/3 17:33
 Re: Leaf springs
cant see any way that it wouldnt be safe, over a long period of time it might start to rub through the main leaf but that should take a while
also it will make your rear end softer
L18_B110
Posted: 2007/4/3 19:27  Updated: 2007/4/3 19:27
 Re: Leaf springs
yes perfectly safe and can be a very effetive mod. I made spring packs for my car like this. With a bit of trial and error tuning you can end up with quite a sophisticated end result.
Tyrie
Posted: 2007/4/3 19:53  Updated: 2007/4/3 19:53
 Re: Leaf springs
thats reassuring, however its a tad to low now, when it squats on aceleration it jambs the exhaust between the diff and body and makes some scary noises
phunkdoktaspok
Posted: 2007/4/3 20:01  Updated: 2007/4/3 20:01
 Re: Leaf springs
There is nothing dangerous about this. In this original spring pack design - all the weight is focused on one spring regardless.
You will find that the suspension changed like this - will be stiffer than reset springs. Reason being that the spring is now held flatter under tension.
Reset springs( more comonly reshaped in a hammer press or heat shaped if making new leaves) reseting them flat takes away the stiffness because there is less arc to supply load to. You need to add extra leaves to then supply the lost stiffness.
Extra leaves means more unsprung weight and we know thats just terrible isnt it.
Now we all know that this mod is done to lower the vehicle height.
So what do we want?
Stiffer or close to standard rate springs?
Reset and now softer springs that give more travel that we cant use?
Or stiffer springs which give more unsprung weight?
Tyrie
Posted: 2007/4/5 18:11  Updated: 2007/4/5 18:11
 Re: Leaf springs
soo anyone want to buy a pair of pre-lowered springs? Should work well with atandard or thin exhaust... $20
Tyrie
Posted: 2007/4/2 18:26  Updated: 2007/4/2 18:26
 Re: Leaf springs
the second from bottom leaf is now upside down on the top. Is it safe to be like this?
Curtis
Posted: 2007/4/2 20:01  Updated: 2007/4/2 20:01
 Re: Leaf springs
i see no problem with it, was told(by my boss) that when u get reset properly all they do is heat em with a oxy and bend them to shape using a preset rig. So if its safe to do that i gess theres no problem with this.
