Main : Mechanical : Suspension Datsun 1200 ute rear leaf spring mount
[<   Previous  365  366  367  368  369  370  371  Next   >]
Datsun 1200 ute rear leaf spring mountPopular
SubmitterWattageMore Photos from Wattage   Last Update2007/4/29 22:06    Tell a friendTell a friend
Hits5369  Comments4    0.00 (0 votes)0.00 (0 votes)
1200 ute rear spring perch that needs to be moved inwards in order to mini-tub
PIGDOG
Posted: 2007/4/29 22:37  Updated: 2007/4/29 22:37
 Re: Datsun 1200 ute rear leaf spring mount
wouldnt that technically make it just tubbing.....dont you only go to the chassis rail when mini tubbing
Wattage
Posted: 2007/4/29 22:46  Updated: 2007/4/29 22:46
Yeah, but I'm not actually moving the chassis rails, only the spring mount...
Then, I'll just cut out the wheels tubs and make the wheels fit.
If I was doing a full tub, theoretically, I could move (make new) rails inboard as far as I like to fit the biggest rubber possible. Mini-tubbing involves modification made to get the wheel as close to the staandard chassis rails without actually moving it...
PIGDOG
Posted: 2007/4/29 22:59  Updated: 2007/4/29 22:59
just looking at the rear one.....really need to find another ute to get the mounts off and the rail that they are attatched to
then just weld that in beside the original rail, then get rid of the old mount
Wattage
Posted: 2007/4/30 1:57  Updated: 2007/4/30 1:57
Yeah, that could work actually. still appears stock too. Short of that, I reckon I might cad up a bracket and get my water jet dude to cut one out...hrmmm, now for the front mount, thats the difficult one!
