Main : Members : PIGDOG r31 diff vs h165
[<   Previous  92  93  94  95  96  97  98  Next   >]
r31 diff vs h165
r31 diff vs h165Popular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2007/5/14 12:04    Tell a friendTell a friend
Hits4787  Comments20    0.00 (0 votes)0.00 (0 votes)
finally got these pics off the camera
r31 doesnt look hugely bigger
picko
Posted: 2007/7/17 12:32  Updated: 2007/7/17 12:32
 Re: r31 diff vs h165
pigdog... how much was it to shorten and do you have a ford lsd in it?
PIGDOG
Posted: 2007/7/17 12:38  Updated: 2007/7/17 12:38
good thing i was online, never would have seen that otherwise
i shortened the housing myself and did the mounts, so that cost nothing
cost $110 to have the axle cut down and resplined
just an open centre at the moment, but will be running a ford LSD once i have the money to get one
hotrocket
Posted: 2008/1/29 9:52  Updated: 2008/1/29 9:52
HI NICK.... HOW MUCH DID YOU CUT OFF,
I HAVE THE SAME R31 DIFF ASWELL FOR MY 1200 UTE,
WHEN YOU HAD THE AXLE CUT DOWN DID THEY NEED THE CENTRE ASWELL
phat_dat1200
Posted: 2007/5/14 15:23  Updated: 2007/5/14 15:23
i've got 13s on mine with about 2mm clearance
PIGDOG
Posted: 2007/5/14 15:27  Updated: 2007/5/14 15:27
yeah i think i was just to lazy to find a 13...might do that so i know what i can put on there if one of my tyres dies
Tyrie
Posted: 2007/5/14 15:46  Updated: 2007/5/14 15:46
I put 13s on mine, just had to trim the caliper cooling fins by a couple of millimetres. This was with an alloy wheel, a steelie wouldnt fit without lots of work.
got a pic of r31 axle and h165 axle next to each other?
PIGDOG
Posted: 2007/5/14 15:50  Updated: 2007/5/14 15:50
no, but have a pic next to a 145 axle
we can pretend its a 165 axle
i can get a pic of the 28 spline next to a h165 axle, just requires me pulling an axle out of the ute diff
PIGDOG
Posted: 2007/5/14 16:16  Updated: 2007/5/14 16:16
the cut down axle looks better coz it doesnt go under sized.....but this will do
Tyrie
Posted: 2007/5/14 16:20  Updated: 2007/5/14 16:20
haha i can kinda see why the r31 axles would be stronger...
PIGDOG
Posted: 2007/5/14 16:26  Updated: 2007/5/14 16:26
maybe if we just wrap the 145 axle in tape till its the same size, then it will save the hassle of cutting down a diff
BUNDY351
Posted: 2007/5/15 5:06  Updated: 2007/5/15 5:06
as long as you use 100Mph tape she will hold up just fine
matbighat
Posted: 2007/5/15 11:25  Updated: 2007/5/15 11:25
this is for drag/street? i can't imagine you'd want something like that weighing you down at the circuit or autox ...
Tyrie
Posted: 2007/5/15 13:02  Updated: 2007/5/15 13:02
well its almost cheaper to do this and get an LSD than it is to get a h165 LSD, so there's one bonus, and you dont have to worry about collecting diffs to replace broken parts. IMO these benifits outweigh the cost of the extra weight
phat_dat1200
Posted: 2007/5/15 15:32  Updated: 2007/5/15 15:32
this is a pic of my r31 axels
cheater_5
Posted: 2007/5/14 14:34  Updated: 2007/5/14 14:34
ifff onnnllyyy it fitted 13's
PIGDOG
Posted: 2007/5/14 14:39  Updated: 2007/5/14 14:39
machine the disk down and run different calipers... or just get rid of the disks and go to drums
edit: come to think of it, if you get rid of the handbrake crap (run commodore rear calipers) then 13s should fit
Jake77
Posted: 2007/5/14 14:54  Updated: 2007/5/14 14:54
Prob a silly question, but does the tailshaft mate straight up?
Jake77
Posted: 2007/5/14 15:04  Updated: 2007/5/14 15:04
Also whats the outside measurements disk to disk
PIGDOG
Posted: 2007/5/14 15:06  Updated: 2007/5/14 15:06
you would be surprised... different flange (need the BW flange on the tailshaft and to redrill 2 holes in the diff flange) but length of tailshaft is the same
width is 20mm wider than standard after i cut it down
Jake77
Posted: 2007/5/14 15:09  Updated: 2007/5/14 15:09
Whats the the uncut measurements?
Did you only cut one side down?
PIGDOG
Posted: 2007/5/14 15:14  Updated: 2007/5/14 15:14
un cut its 1452mm
cut down both sides, used short axle as the long one and got the long axle cut down 135mm
Jake77
Posted: 2007/5/14 15:18  Updated: 2007/5/14 15:18
Thanks for the info
