Main : Misc weber
[<   Previous  2963  2964  2965  2966  2967  2968  2969  Next   >]
weber
weberPopular
SubmitterdatsunnyMore Photos from datsunny   Last Update2007/5/6 22:06    Tell a friendTell a friend
Hits2817  Comments8    0.00 (0 votes)0.00 (0 votes)
wat the hell is with the fuel lines??
datsunny
Posted: 2008/6/14 1:56  Updated: 2008/6/14 1:56
 Re: weber
Thanks for the help guys!
This was actually on my starlet, i put a 1500cc toyota van motor in it. Had a nightmare setting up that carb.
When i sold the car, the fuel pressure regulator gauge decided to spring a leak and spill fuel all over the hot exhaust manifold. not a good look when u r trying to sell the car!!
kululadotgroen
Posted: 2007/5/7 0:40  Updated: 2007/5/7 0:40
 Re: weber
Unless you are going to use some kind off high pressure fuel pump that might be able to push the needle open and flood the carb/engine, do as datrat_dave said, simply use the most convenient one as the inlet, and block the other off. The standard fule pump won't be able to push the needle open, and I think most of the fasset type ones wouldn't either just check their pressure ratings.
Posted: 2007/5/7 17:20  Updated: 2007/5/7 17:20
 Re: weber
Don't use it as a "return line" as it will drop the pressure to almost nothing. Almost no carburetors use a return line, except some late emission-controlled models.
The Weber comes in left-hand and right-hand models. But both use the same casting. Usually one side is plugged, or not even drilled.
For more details, see 1200 Encyc - Weber 32/36
datrat_dave
Posted: 2007/5/8 2:01  Updated: 2007/5/8 2:01
 Re: weber
ive used a 32/26 on a standard sunny fuel system, nothing different and a mate used it on a 120y and 1200 standard system to with no dramas
Some say you need a high pressure fuel pump but thats really only if your running a high powered engine, A series should be fine with the mechanical fuel pump as it creates about 3 - 4 psi of pressure anyway - more than ample for a 32/36.
when adding SU's or twins thats another question tho.
Cheers
Dave
WhiteSedan
Posted: 2007/5/8 2:07  Updated: 2007/5/8 2:07
 Re: weber
Its not the fuel pressure its the flow, standard fuel pump should be adequate for the 32/36.
For webers you dont need much more than 1.5psi, the stock fuel pump may not have enough flow. You have to watch the fuel pressure doesnt drop at high revs, if it does you need more flow.
Posted: 2007/5/9 18:34  Updated: 2007/5/9 18:34
 Re: weber
Actually it *is* the fuel pressure. Fuel pressure is critical to float spillage. Redline recommends 2.5 to 3 lbs -- far more than 1.5 lbs. This is thankfully exactly what the 1200 pumps put out.
Regarding volume (flow), the Datsun 1200 stock pump puts out plenty of volume for almost 200 hp if working to specification. Test yours to be sure.
datrat_dave
Posted: 2007/5/6 23:44  Updated: 2007/5/6 23:44
 Re: weber
Only need to use one inlet mate, they can both be used as an inlet as they both lead to the same fuel bowl. Just block one off with a T piece of plug the line already on there and use the easiest/closest one to your fuel line.
