Main : Mechanical : Engine A12 turbine
[<   Previous  2233  2234  2235  2236  2237  2238  2239  Next   >]
A12 turbine
A12 turbinePopular
Submitterdat18More Photos from dat18   Last Update2007/5/28 10:43    Tell a friendTell a friend
Hits3279  Comments10    0.00 (0 votes)0.00 (0 votes)
Head shim and dbl valve springs
datsun_lover
Posted: 2008/5/26 5:25  Updated: 2008/5/26 5:25
Quite a regular
 Re: A12 turbine
what gearbox and axe relationship are you using?
minitruckin
Posted: 2008/5/26 5:46  Updated: 2008/5/26 5:46
 Re: A12 turbine
lools good.... what power are you putting out?
dat18
Posted: 2007/8/2 1:34  Updated: 2007/8/2 1:34
Quite a regular
 Re: A12 turbine
Its only oiled cooled, after a trash it still not even hot, no where near hot enogh to fuk seals or bearings. That carby hat is sealed wit silicon not welded. i run a 7psi carter pump. Stock carb with float level bumpt up and 2nd jet drilled out. It realy isn't rocket science to do and make work.
Velociti
Posted: 2007/5/30 16:22  Updated: 2007/5/30 16:22
 Re: A12 turbine
My buddy,s got the same setup, with a non-return valve on the fuel line.
Only problem his got is, he keeps blowing the head gasket. Still running origanal pistons, to much boost, cant set it. Advice on this one will be appreciated.
3x 1/4 runs = 1x new head gasket.
Posted: 2007/6/1 18:51  Updated: 2007/6/1 18:51
 Re: A12 turbine
The standard carb can easily take 5 pounds of boost. It won't fill the gas tank (1200s like most carbureted cars don't have a return fuel line).
For more information, see wiki -- blow-through turbocharging
Lotto
Posted: 2007/5/30 13:52  Updated: 2007/5/30 13:52
 Re: A12 turbine
Is that std carb??? the turbo is going to fill the fuel tank ..............air lots of air.
You nead a turbo carb from other car
beattie
Posted: 2007/5/28 11:44  Updated: 2007/5/28 11:44
 Re: A12 turbine
thats one way to make sure the carby is sealed! weld the fecking thing!
Whats with the massive reducer just after the turbo on the inlet side?
PIGDOG
Posted: 2007/5/28 11:50  Updated: 2007/5/28 11:50
 Re: A12 turbine
i was wondering that too, didnt think the inside of the turbo would be that increadably small
kegs
Posted: 2007/5/28 12:17  Updated: 2007/5/28 12:17
 Re: A12 turbine
one way to get rid of that haggard reducer is to cut the triangle flange off the turbo round it with a grinder and put silicon hose on it
Daveman
Posted: 2007/5/28 13:04  Updated: 2007/5/28 13:04
 Re: A12 turbine
what are the unused pipes around the turbo? They aren't neglected water lines are they?
