Main : Members : PIGDOG new brakes version 4 REARS
[<   Previous  77  78  79  80  81  82  83  Next   >]
new brakes version 4 REARSPopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2007/6/23 11:11    Tell a friendTell a friend
Hits1973  Comments7    0.00 (0 votes)0.00 (0 votes)
the new 300zx rear brakes, just fit inside trx rims....well they will once the disc is machined down to 290mm and the back of the spokes ground down a bit on the rims
but they are huge
PIGDOG
Posted: 2007/6/24 12:00  Updated: 2007/6/24 12:00
 Re: new brakes version 4 REARS
wow these discs are really hard...took about a half hour to machine that 7mm off the diameter, 4th lathe tool did the job though
so they will be going on tomorrow if i have time for some on car pics
then i attack the TRX rims with the grinder
ANGE
Posted: 2007/6/24 12:13  Updated: 2007/6/24 12:13
thats it. youve gone brake mad!
black ban on the brakes.
build yourself a tuff L donk, and finish off your paint job already!!
stanza brakes are so under-rated!
boofhead
Posted: 2007/6/24 12:31  Updated: 2007/6/24 12:31
once you've finished on the trx rims you can start work on a rear set up to suit the h165 in my sedan !!!
PIGDOG
nah ANGE thats the reason that i bought these, i CANNOT physically fit larger brakes in the car
so now i cant spend any more money on the brakes, i can only build kits to sell to fund said building of tuff L series
EDIT: yeah adrian i might need to borrow some wheels from you to see what these brakes will fit in
i'll find some smaller discs for you, then i could start on a kit
Mildman
Posted: 2007/6/24 12:36  Updated: 2007/6/24 12:36
I'll have to trawl down to Geelong one day and see these monster brakes....I bet one track day in my coupe and I'll be begging for bigger....but under 13" rims which might make it somewhat harder.
boofhead
Posted: 2007/6/24 12:37  Updated: 2007/6/24 12:37
if you must
the skyline rims are just sittin there, the 13's will have tyres on them by tomorrow night and it's not too difficult to get one of the white ones off the sedan ....
what are you doing in the way of a handbrake ??
PIGDOG
Posted: 2007/6/24 12:43  Updated: 2007/6/24 12:43
handbrake????
might be looking into a hydraulic one some day, or there is the one that datsports uses for their kit....not really a hig priority right now as i didnt have the r31 handbrake setup
i now know where i can get the calipers for $60-80....found them after i'd payed twice that for these
so once i find a 260ish mm disc that has enough of an offset for the rear then ill be able to make some that fit under 13s
oh and the other 5 stud wheels are definatly out....even with the spacers the brakes didnt come close to fitting, so its back to the trusty trexys
