Main : Members : PIGDOG 300zx rear brakes
[<   Previous  75  76  77  78  79  80  81  Next   >]
300zx rear brakes
300zx rear brakesPopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2007/6/25 11:16    Tell a friendTell a friend
Hits2157  Comments5    0.00 (0 votes)0.00 (0 votes)
just fit under TRX rims once modded
PIGDOG
Posted: 2007/6/25 11:24  Updated: 2007/6/25 11:24
 Re: 300zx rear brakes
as you can see, very little clearance....looks like a bit in this pic below but thats at the back of the caliper, same amount of caliper on the other side of the rim where it tapers down, can see how close it is to the little hump on the caliper
and the caliper will be raised up a mm or 2
LittleFireyOne
Posted: 2007/6/25 11:34  Updated: 2007/6/25 11:34
What axle have you been adapting this to?
PIGDOG
Posted: 2007/6/25 11:39  Updated: 2007/6/25 11:39
R31, would have tried the handbrake too....but couldnt get a handbrake setup to work with
2QK4U
Posted: 2007/6/25 16:35  Updated: 2007/6/25 16:35
Pigdog tell me if this will work on the TRX rear disc set up? disc over drum so no handbrake for me to worry about...
PIGDOG
Posted: 2007/6/26 2:59  Updated: 2007/6/26 2:59
if you measure the drum handbrake diameter on the bluebird setup i could let you know, as these discs are designed for drum in disc it may be possible
im yet to actually see the skyline drum handbrake setup so i dont know how hard that would be to adapt
also dont know what the caliper mounts would be like....maybe have to nab boofs bluebird diff for testing
