Main : Members : PIGDOG 300zx brakes onto r31 diff
[<   Previous  73  74  75  76  77  78  79  Next   >]
300zx brakes onto r31 diffPopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2007/6/26 11:45    Tell a friendTell a friend
Hits4440  Comments7    0.00 (0 votes)0.00 (0 votes)
got the bracket pretty much sorted today, offset isnt quite right yet
but ill get it spot on when the alloy bracket is made
PIGDOG
Posted: 2007/6/26 12:12  Updated: 2007/6/26 12:12
 Re: 300zx brakes onto r31 diff
brakes on the car
showing offset of caliper
just a caliper pic
my fake diff assembly used for fitment
where the caliper hits the rim, grinder will solve that
the almighty mdf bracket
16mm aluminium waiting to be cut
lastly the mdf bracket on the r31 caliper bracket....on the diff
WhiteSedan
Posted: 2007/6/26 13:27  Updated: 2007/6/26 13:27
Good stuff man, if you used a smaller diameter rotor that didnt come from a disc over drum setup reckon you could get 14's over it? I dont need a handbrake.
How will the aluminium stand up to hard braking? I would look into steel maybe.
PIGDOG
Posted: 2007/6/26 13:45  Updated: 2007/6/26 13:45
if you can find a smaller disc with a large offset like these then you could make them clear, i was looking at the dba catalouge last night and found one...but forget what it was
dont know how the alloy bracket will hold up....but 16mm steel would weigh a tonne and be really hard to cut
so ill make these and see if it stretchs the bolt holes or anything
planned on using some aircract grade 12mm aluminium for the front bracket, it seems nice and hard
LAGWAGON
Posted: 2007/6/26 15:09  Updated: 2007/6/26 15:09
cool, looks achievable so is the proper offset for the caliper gonna hit the wheel more?
i'd think thwice about grinding the wheel, the balance will be all over the place, unless you have a special way of doing it...
Daveman
Posted: 2007/6/26 15:45  Updated: 2007/6/26 15:45
It's hard to work it out from the pics but if it's just the nissan sign on the caliper scraping just grind the caliper down.
PIGDOG
Posted: 2007/6/27 11:47  Updated: 2007/6/27 11:47
with the standard discs the caliper will always hit the wheel, it hits just above the nissan bit...so cant really grind it off the caliper
its not much that i have to grind off the rim so it shouldnt affect the balance of them to much, nothing a few wheel weights cant fix
or i could go get it put in one of the many huge lathes i have acces to....but thats if just grinding doesnt work
any way, made one of the alloy brackets today. took all day coz the 4 inch decided to die just after i started cutting, so had to use the hacksaw all day
this is basic hacksawing
then after spending an hour or so with the diegrinder and files
and the second bracket where i left it tonight, forgot to take a pic of the complete one
WhiteSedan
Posted: 2007/6/27 11:54  Updated: 2007/6/27 11:54
Fark me, that would of been fun with a hacksaw! Are you going to tap the bracket so you dont have to use nuts?
PIGDOG
Posted: 2007/6/28 11:58  Updated: 2007/6/28 11:58
ok finished them today and started on wheel clearance....only just have to grind the casting imperfectings off the back of the wheel now and the caliper will clear
so some more pics
finished bracket bolted to r31 bracket, tapped a thread then put a nut on the end...just to be safe
and the back, with safety nuts
the 2 finished brackets...as rough as they do look
and where the wheel was hitting the caliper, took to it with the file. needed less than 1mm taken off to clear the wheel enough
so now all thats left is to get the other disc lathed down and to sort out brake lines, the flexy lines will be a quarter of the cost of the conversion themselves
oh and yes hacksawing was great fun
Anonymous
Posted: 2007/6/26 11:52  Updated: 2007/6/26 11:52
mdf.... thats my kind oh half arsed style
looks good nick,
