Main : Mechanical : Engine ahhh finally my turbo is getting fitted
[<   Previous  2200  2201  2202  2203  2204  2205  2206  Next   >]
ahhh finally my turbo is getting fittedPopular
SubmitterfrankthedolphintrainerMore Photos from frankthedolphintrainer   Last Update2007/8/3 0:11    Tell a friendTell a friend
Hits3418  Comments13    0.00 (0 votes)0.00 (0 votes)
piccy of a12t and the progress in the ute
sidedraught
Posted: 2007/8/3 4:34  Updated: 2007/8/3 4:34
 Re: ahhh finally my turbo is getting fitted
Must be great to see all the hard work starting to pay off Jake.
Nice turbo by the way.
Posted: 2007/8/3 4:40  Updated: 2007/8/3 4:40
thanks andy i still think it would have been better on yours, as for the turbo i had to cut a big peice of it of, it was like a mount or somthin thats not being used anymore. you can just se on the right hand side where i cut it off
beattie
Posted: 2007/8/3 4:56  Updated: 2007/8/3 4:56
NICE! Definatly wont fit a 1000 looking at that pic! Way too low!
What turbo you running? And are you decompressing etc?
Posted: 2007/8/3 4:58  Updated: 2007/8/3 4:58
yeah this one the ihi rhf5 sits lower than the t25s, as for the decompression havnt gottne that far yet still dont know weather im going to bother
1200rallycar
Posted: 2007/8/3 5:04  Updated: 2007/8/3 5:04
no point decompressing unless going over 10 or even 12 psi (at roughly these points you need better head gasket, pistons etc etc anyway)
just adds lag if you do
Posted: 2007/8/3 5:08  Updated: 2007/8/3 5:08
yeah it will be at stock turbo psi to start with which i think is 7.2psi
1200GXman
Posted: 2007/8/3 5:14  Updated: 2007/8/3 5:14
What about a slightly thicker head gasket just to be save with regard to detonation?
1200rallycar
Posted: 2007/8/3 7:58  Updated: 2007/8/3 7:58
theres other ways to avoid it without decompressing
like retarding the timing or intercooling / water injection
why negatively effect the off boost performance when you dont have to?
A14force
Posted: 2007/8/3 14:59  Updated: 2007/8/3 14:59
Will this be drawthrough or blowthrough? The turbo intake seems too close to the bottom radiator hose to allow fitment of a carbie.
No biggie though I 'spose. I've cut my tube right down to gain clearance on my blown engine.
Posted: 2007/8/3 15:28  Updated: 2007/8/3 15:28
its a blow through the one with the carby after the turbo
BUNDY351
Posted: 2007/8/3 17:02  Updated: 2007/8/3 17:02
Looking good bud (the ute that is). Cant wait to see it close up.
1200rallycar
Posted: 2007/8/3 17:42  Updated: 2007/8/3 17:42
which carby? are you going to box it?
i think most people end up going injection after they try blow through.... too many problems with carby
i did.....
Posted: 2007/8/3 17:48  Updated: 2007/8/3 17:48
well im going to try a 32/36 weber that imusing already and see how i go with the carby box or carby hat im still trying to figure out the best way for the throttle if i go with boxed
