Main : Misc what do you peoples think?
[<   Previous  2548  2549  2550  2551  2552  2553  2554  Next   >]
what do you peoples think?Popular
SubmitterfrankthedolphintrainerMore Photos from frankthedolphintrainer   Last Update2007/8/6 22:19    Tell a friendTell a friend
Hits2144  Comments6    0.00 (0 votes)0.00 (0 votes)
i this problem, where should i put the air filter
Posted: 2007/8/6 22:22  Updated: 2007/8/6 22:22
 Re: what do you peoples think?
my thoughts are, that if i put it as in piccy 1 ill be copping all the heat (not that much) of the radiator where as in the second piccy i will loose my window washer bottle and it still wont have much air flow due to the light being in the way, unless its at the drags and i take the light out(probly never happen)
Tyrie
Posted: 2007/8/6 22:38  Updated: 2007/8/6 22:38
lose the washer bottle, replace it with a kangaroo bag
Posted: 2007/8/6 22:51  Updated: 2007/8/6 22:51
but do you think it will get enough air flow in that corner
Tyrie
Posted: 2007/8/6 23:04  Updated: 2007/8/6 23:04
yep plenty, it doesnt need to be waving out in the wind. If you want more air run some ducting from the front to the air filter.
steveo
Posted: 2007/8/7 3:48  Updated: 2007/8/7 3:48
My air filter is in the corner. i cut a 100mm square peice of metal between the light and the radiator support, i had the same thought u had when i was getting putting mine together, seems to work fine, but as tyrie said if u need more just runn some ducting to the filter.
1200rallycar
Posted: 2007/8/7 16:53  Updated: 2007/8/7 16:53
you can see mine here, i found that the intercooler pipe was always hot so i shielded the pod with some bent ally, this also ducted air from the hole in the radiator support
i have never put the shield into the ute though, its hard to tell with these things, unless you had some thermometers from jaycar or whatever i dont think you are really going to notice the difference
