Main : Members : ANGE : Other new stoppers
[<   Previous  36  37  38  39  40  41  42  Next   >]
new stoppers
new stoppersPopular
SubmitterANGEMore Photos from ANGE   Last Update2007/8/13 21:53    Tell a friendTell a friend
Hits4000  Comments14    0.00 (0 votes)0.00 (0 votes)
250mm vented discs and calipers from an s13.
dongdong0507
Posted: 2007/8/14 14:30  Updated: 2007/8/14 14:30
 Re: new stoppers
looks same with mine that is going to be installed in my b310. but mine using S13 knuckle, disc brake, hub, S13 coilover, others using B310 stuffs like lower arm and tie ends
Team_Dat
Posted: 2007/8/14 15:07  Updated: 2007/8/14 15:07
 Re: new stoppers
is the early stanza the same as the sunny strut?
if so i may have found the brake upgrade i'm looking for....
PIGDOG
Posted: 2007/8/14 17:10  Updated: 2007/8/14 17:10
 Re: new stoppers
early stanza may be the same as sunny struts, but they would be different to 120y struts i would think.....maybe
ANGE
Posted: 2007/8/14 18:07  Updated: 2007/8/14 18:07
 Re: new stoppers
15's fit fine.
im currently running 15x5.5 on the front which clear the spring cup and the strut itself by a country mile.
but i also tried my old 15x6 skyline wheel on
and that fit aswell. snug but it fits.
i havent cut the strut down yet as i wanted to trial it first before spending a lot on the setup. hasnt bottomed out at all yet which is good but i will be putting inserts in them soon wether they be shorter or not. time will tell.
no pics of the stub axle sorry.
grant76
Posted: 2007/8/14 10:01  Updated: 2007/8/14 10:01
 Re: new stoppers
so does the s13 fit on 120y 210 struts or sunny b310 120y struts, or both??
WhiteSedan
Posted: 2007/8/13 21:57  Updated: 2007/8/13 21:57
 Re: new stoppers
Nice! Those calipers look identical to my 280zx ones.
All this on a 120y strut am I correct? Is there any worries about the size of the wheel bearings and stub axle with large brakes like this?
ANGE
Posted: 2007/8/13 22:09  Updated: 2007/8/13 22:09
 Re: new stoppers
yes you are correct.
later model 120y's (with PBR calipers) have a larger stub axle, and this is the one ive used.
theres nothing to worry about. This setup has been used by many before me.
BAD310
Posted: 2007/8/13 23:13  Updated: 2007/8/13 23:13
 Re: new stoppers
This is the same brake combo I will be using.
I had a set of 120Y struts but noticed the Sunny struts I have had bigger stub axles, so I am using the Sunny ones, the 120Y struts I had may have been off an earlier model. I am guessing that your struts have the same size stub axles as Sunny struts.
Ange, have you done anything with the strut body? Like cut it down in length? Just curious, as I am doing this in the next week or so.
Cheers
1200rallycar
Posted: 2007/8/13 23:19  Updated: 2007/8/13 23:19
 Re: new stoppers
so.... how are you going to fit 15s now?
will they fit?
BAD310
Posted: 2007/8/13 23:39  Updated: 2007/8/13 23:39
 Re: new stoppers
I have 15s and they fit over the same brakes on a silvia so I dont see why they wont fit over them on another strut. Is there something I am not seeing?
I am not sure of the offset of my wheels but they are 15x7.5 with ~ 0 offset, so the centres will have to be moved out to get the tyre under the guard.
1200rallycar
Posted: 2007/8/13 23:53  Updated: 2007/8/13 23:53
 Re: new stoppers
i thought 120y struts had the same problem as 1200 ones, any bigger in wheels/tyres and you start hitting the spring cup
BUNDY351
Posted: 2007/8/14 7:36  Updated: 2007/8/14 7:36
 Re: new stoppers
I am running STD silvia front calipers and rotors on 120Y struts. I am running 15in X5.5in TRX mags with 205/50's and I am real dam close to the lower spring cup. I could not go any wider in tyres.
PIGDOG
Posted: 2007/8/14 9:55  Updated: 2007/8/14 9:55
 Re: new stoppers
dont happen to have any pics of the stub axle, or measurement would you
it would be interesting to see if the stub axle is the same as sunny ones (smaller than stanza and what not)
Jake77
Posted: 2007/8/13 23:21  Updated: 2007/8/13 23:21
 Re: new stoppers
Looks very nice...
Same disc and calliper ive just installed, but im using S13 LCA's, S13 radius rods and ISC Coilovers. Will post How to's when ive finished. Sorry to go off track.
Again Nice work.
qik1000
Posted: 2007/8/14 18:36  Updated: 2007/8/14 18:36
 Re: new stoppers
Looks good!
Nice long wheel studs too!!
Do you have a pic of the inside ?
Where did you get those buy the way??
ANGE
Posted: 2007/8/14 18:58  Updated: 2007/8/14 18:58
 Re: new stoppers
the studs came from the s13 that donated its calipers
this is the only pic ive taken
