Main : Misc : Tech Section VanDiscSkylineCaliper
[<   Previous  235  236  237  238  239  240  241  Next   >]
VanDiscSkylineCaliperPopular
SubmitterBigVMore Photos from BigV   Last Update2007/10/31 23:57    Tell a friendTell a friend
Hits3089  Comments5    0.00 (0 votes)0.00 (0 votes)
Stanza strut with stanza hub with the large vannett vented rotor (bolt on) had strut mounting lugs machined flat on back and the holes offset drilled closer to stub axel taking out the thread as skyline callipers are threaded. Then had approx 8mm machined of the callipers mounting lugs to get the offset correct this would depend on how much need to be taken of the mounting lugs on the strut to get them flat. With a little relieving of the cooling fins on the calliper they fit inside 13inch hotwires.
racer135
Posted: 2014/8/6 13:16  Updated: 2014/8/6 13:16
 Re: VanDiscSkylineCaliper
What model Vanette did the vented rotors come from?
Posted: 2014/8/21 11:22  Updated: 2014/8/21 11:22
some C120 Vanette came with vented rotors:
* 238 mm rotors on June 1981 up GL
* 250 mm rotors on June 1981 up GS
see 910_Brakes#Specifications
Tyrie
Posted: 2007/11/1 2:33  Updated: 2007/11/1 2:33
how thick are the caliper mounting lugs after machining 8mm off?
BigV
Posted: 2007/11/1 13:20  Updated: 2007/11/1 13:20
they are still thicker then the rest of the calliper bracket
they basically have a section in the lug with no thread for 10mm then the threaded section so I havnt removed any of the threaded section of the calliper
andrew1200
Posted: 2014/9/8 10:33  Updated: 2014/9/8 10:33
Quite a regular
hi Guys have done this exact think on my 1200 ute but run datsun blue bird trx disc on the back also with 120y booster and 7/8 master cylinder does'nt lock rears fantastic brack set up But i ran stanza front legs and lower control arms { girlock calipers } and changed the rotors with c20 vanette rotors and calipers regards Andrew
