Main : Misc : Tech Section VanDiscSkylineCaliper2
[<   Previous  234  235  236  237  238  239  240  Next   >]
VanDiscSkylineCaliper2Popular
SubmitterBigVMore Photos from BigV   Last Update2007/10/31 23:58    Tell a friendTell a friend
Hits2331  Comments0    0.00 (0 votes)0.00 (0 votes)
Stanza strut with stanza hub with the large vannett vented rotor (bolt on) had strut mounting lugs machined flat on back and the holes offset drilled closer to stub axel taking out the thread as skyline callipers are threaded. Then had approx 8mm machined of the callipers mounting lugs to get the offset correct this would depend on how much need to be taken of the mounting lugs on the strut to get them flat. With a little relieving of the cooling fins on the calliper they fit inside 13inch hotwires.
