Main : Mechanical : Drive Train Modified Clutch Bearing Carrier
[<   Previous  597  598  599  600  601  602  603  Next   >]
Modified Clutch Bearing CarrierPopular
SubmitterTomMcKayMore Photos from TomMcKay   Last Update2008/1/11 22:54    Tell a friendTell a friend
Hits2797  Comments4    0.00 (0 votes)0.00 (0 votes)
Clutch release bearing carrier extended from 43.5 to 47mm.
works1200
Posted: 2008/1/11 23:55  Updated: 2008/1/11 23:55
 Re: Modified Clutch Bearing Carrier
and what are the benefits of this..? thanks
TomMcKay
Posted: 2008/1/12 1:25  Updated: 2008/1/12 1:25
Clutch release bearing now reaches the pressure plate when using a 60-series dogleg box on an A15 motor.
Posted: 2008/1/12 1:27  Updated: 2008/1/12 1:27
Posted: 2015/10/8 5:22  Updated: 2015/10/8 5:24
Tom McKay said:
there seems to be two sizes of bearing carrier. Mine's about 44mm in length.
That is the short B110 type, used with 56A gearboxes. So it follows that the modifed sleeve is now the length of the standard B110 sleeve.
