Main : Mechanical : Drive Train T50 conversion front
[<   Previous  595  596  597  598  599  600  601  Next   >]
T50 conversion frontPopular
Submitterdat141More Photos from dat141   Last Update2008/1/20 8:27    Tell a friendTell a friend
Hits2610  Comments2    0.00 (0 votes)0.00 (0 votes)
This shows how the original release bearing setup can be used, the release bearing guide has to be turned down and the bearing carrier has to be bored out to suit.
qik1000
Posted: 2008/2/11 12:12  Updated: 2008/2/11 12:12
 Re: T50 conversion front
Nice job! I used a different method for mine...instead of turning down the Toyota guide and boring the datsun carrier, I used the stock Toyota guide and carrier but pressed on a Datsun bearing. Then I spend some time opening up the throw-out arm to work with the Toyota carrier. Your way sounds easier if you have access to a lathe. My way only required a grinder.
