Main : Members : ang94541 S13 Disk Brake and Wheel Check
[<   Previous  5  6  7  8  9  10  11  Next   >]
S13 Disk Brake and Wheel CheckPopular
Submitterang94541More Photos from ang94541   Last Update2008/3/2 13:31    Tell a friendTell a friend
Hits3196  Comments5    0.00 (0 votes)0.00 (0 votes)
This is for a thread. S13 brakes onto b110 struts. booyah
Picture shows use of a template of my wheel to check brake fitment.  The template is actually on 10mm spacers.
Western Wheel "minilites", 13x5.5 have a little interference problem.
A14force
Posted: 2008/3/3 5:44  Updated: 2008/3/3 5:44
 Re: S13 Disk Brake and Wheel Check
That small an amount of material could probably be machined off safely.
Tyrie
Posted: 2008/3/3 5:48  Updated: 2008/3/3 5:48
s13 calipers are cast iron are they?
ang94541
Posted: 2008/3/3 7:13  Updated: 2008/3/3 7:13
If you look closely, that template is on 10mm spacers. That adds to the 8mm disk hat. I would prefer to not use the additional 10mm spacer or my wheels will then stick out just enough to hit the fender.
So if you can imagine the spacers gone there is an area about 10x10 that needs to be removed across the width of the caliper.
There's a lot of meat on there. So I think it will be ok to remove. I have to take a closer look
ang94541
Posted: 2008/3/2 13:32  Updated: 2008/3/2 13:32
