Main : Members : ang94541 Another radiator/electric fan view
[<   Previous  49  50  51  52  53  54  55
Another radiator/electric fan viewPopular
Submitterang94541More Photos from ang94541   Last Update2002/8/4 19:51    Tell a friendTell a friend
Hits5530  Comments5    7.50007.50 (2 votes)
I knew i had another pic. This shows the clearance between the fan and pulley a little better. On the lower left side of the radiator is the electronic thermostat for the fan. It has a probe that pushes inbetween the radiator fins to detect water temp.
1200rallycar
Posted: 2002/8/12 6:41  Updated: 2002/8/12 6:41
 Re: Another radiator/electric fan view
yeah his engine is nice its under mechanical/engine in photo album
SLAM1024
Posted: 2002/8/12 14:15  Updated: 2002/8/12 14:15
cheers mate .. ill take a peek
-SLAM1024
shoom
Posted: 2002/9/29 0:51  Updated: 2002/9/29 0:51
just a question, where did you get that oil cap? it looks neat! sure is alot of gizmos for that FI!
ang94541
Posted: 2002/9/29 8:36  Updated: 2002/9/29 8:36
Thanks. I got it from a chunk of aluminum. Turned it on a lathe. Used an index head on a vert.mill to do the notches all the way around. Then drilled and tapped two holes on the bottom to attach the metal clip/thing, from the stock cap. Easy
PS- gizmos are great. no FI, only SU's
PPS- I also made that turnbuckle thing for the alt. Lathe, mill, Left + right hand taps, and 2 rod ends.
SLAM1024
Posted: 2002/8/12 6:32  Updated: 2002/8/12 6:32
Do you have a picture of the full engine?
From what I can see it looks like a tidy job.
-SLAM1024
