Main : Members : B120dat A14 engine2
[<   Previous  85  86  87  88  89  90  91  Next   >]
A14 engine2
A14 engine2Popular
SubmitterB120datMore Photos from B120dat   Last Update2003/6/5 16:03    Tell a friendTell a friend
Hits7247  Comments10    0.00 (0 votes)0.00 (0 votes)
Engine at its next step, head on, timing chain etc, etc,
B120dat
Posted: 2003/6/6 12:42  Updated: 2003/6/6 12:42
 Re: A14 engine2
thanks should have the GO to match it's looks
Lobster
Posted: 2003/6/6 17:14  Updated: 2003/6/6 17:14
 Re: A14 engine2
Is that flywheel lightened? It looks like it is...
teretonga
Posted: 2003/6/6 22:15  Updated: 2003/6/6 22:15
 Re: A14 engine2
Most certainly. Great head work feral!
feral
Posted: 2003/6/7 2:28  Updated: 2003/6/7 2:28
 Re: A14 engine2
I cant claim the head work. It was done by Hans Lovski. He does most of the A12 mini sprinter heads. Does a very nice job and has a good flow bench that he knows how to use properly.
B120dat
Posted: 2003/6/7 4:56  Updated: 2003/6/7 4:56
 Re: A14 engine2
yeah Lobster the flywheel has had a fair bit taken off, it know wieghs 5.5kg compared to the standard 12 or 13 kg
Cable_Tie
Posted: 2004/9/13 21:44  Updated: 2004/9/13 21:44
 Re: A14 engine2
You can tell it is a sprint head, look at the size of those ports! What sorta cam specs are you running? Does it have any bottom end?
B120dat
Posted: 2006/8/28 15:32  Updated: 2006/8/28 15:32
 Re: A14 engine2
Hahah late reply. It is running a mildish cam 30/70 I think. It is sitting on the A14 bottom end full rebuild (all new internals), Flat top ACLs, full balance and Full blueprint out to 1436cc. Done around 30 000kms. Goes hard!
Building up a a15 now to put the head on, a14 block, a15 crank, a15sump, 1601cc, 626 pistons, 40/80 cam, 10.5comp... would be nice to add 20-30bhp
So will probaly have the bottom end for sale at some point soon.
p.s the block is red not pink!! .. just the photo
LoganW
Posted: 2014/9/12 5:57  Updated: 2014/9/12 5:57
 Re: A14 engine2
Old post sorry
Did you manage to get the A15 going those ports look insane how did this thing go?
Can anyone put me onto a link on what is involved in using 626 pistons I want to go to a 79mm bore but struggling to find a clear option
Posted: 2014/9/13 22:19  Updated: 2014/9/13 22:19
 Re: A14 engine2
For 79 mm pistons, see A15 Overbore
Lobster
Posted: 2003/6/6 12:36  Updated: 2003/6/6 12:36
 Re: A14 engine2
It looks very pretty.
