Main : Mechanical : Engine Cracked A14 Crankshaft Pulley
[<   Previous  2060  2061  2062  2063  2064  2065  2066  Next   >]
Cracked A14 Crankshaft PulleyPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2008/4/14 5:06    Tell a friendTell a friend
Hits2194  Comments5    0.00 (0 votes)0.00 (0 votes)
Oil leaky from crack
A14force
Posted: 2008/4/14 7:51  Updated: 2008/4/14 7:51
 Re: Cracked A14 Crankshaft Pulley
I've seen a few do that
Posted: 2008/4/15 0:38  Updated: 2008/4/15 0:38
I'm wondering if a previous owner didn't have the key in correctly and just forced the pullley on...
Davo1200
Posted: 2008/4/16 7:43  Updated: 2008/4/16 7:43
I had a cracked pulley once. Not sure what causes this? I never pulled the pulley off until a rebuild and found the problem. I assume its force + weak part.
wardat
Posted: 2008/4/16 8:48  Updated: 2008/4/16 8:48
this is a pretty common thing on high reving a-series the way we have fixed it is to get a sleave pressed onto to the pully and then get a different seal with a larger inside diameter to suit the sleave.
