Main : Mechanical : Engine nutcases L20 120y
[<   Previous  2755  2756  2757  2758  2759  2760  2761  Next   >]
nutcases L20 120y
nutcases L20 120yPopular
SubmitternutcaseMore Photos from nutcase   Last Update2003/6/9 6:42    Tell a friendTell a friend
Hits5199  Comments4    0.00 (0 votes)0.00 (0 votes)
yes the car is ugly but GOOD LORD it pulls hard I would say with the L-20 it pulls in 4th gear like the A-14 in second or first just insane power to weight ratio
jaimecidpedro
Posted: 2003/6/9 8:09  Updated: 2003/6/9 8:09
 Re: nutcases L20 120y
C'mon guys, do not be mean, it is not that bad, just get rid of the bumpers, lower the suspension, some mean rubber,wide wheels,and you'll see. May I recommend 13X9 rear with 215/50/13 and 13X8 front,215/50/13 tires. ADDCO sway bars, konis,etc...........
Jaime.
_______________________________
Posted: 2003/6/9 8:26  Updated: 2003/6/9 8:26
hehe. I think what Nutcase meant is that his car needs new paint. OK so it isn't as beautiful as a 1200 (hehe) ... but it will look good I'm confident. It's already beautiful under the hood with that L20B all polished up.
Posted: 2003/6/9 8:39  Updated: 2003/6/9 8:39
What Nutcase didn't mention is that this had a Miata (B18?) engine in it previously. For some reason I found that very surprising.
nutcase
Posted: 2003/6/9 10:02  Updated: 2003/6/9 10:02
actually I plan on flaring the car first then it will get 14x7 with 215/60/14 rubber and 5-speed (long story) after all that it will get paint
oh yeah, the b18 was a miata b18es and it bolted right in, but I couldn't steer. it was resting on the cross link and had it in a bind, so out it came, I am working on a solution and it may go back in..... mabey verrrrry mabey.
nutcase
Posted: 2003/6/9 10:30  Updated: 2003/6/9 10:30
BTW the susp on the car is modded I have new strut inserts in the front w/240z springs shortened 2" and the rear has performance shocks. I also have addco all around
stealth is the momentary key ..... sod that make it look GO too!!!!!!!!!
