Main : Mechanical : Engine Carbies
[<   Previous  2752  2753  2754  2755  2756  2757  2758  Next   >]
Carbies
CarbiesPopular
SubmitterMYB110More Photos from MYB110   Last Update2003/6/15 2:34    Tell a friendTell a friend
Hits5064  Comments16    0.00 (0 votes)0.00 (0 votes)
Twin 45mm Webers 30mm chokes/putting 34mm chokes in before dyno.
jaimecidpedro
Posted: 2003/6/16 8:38  Updated: 2003/6/16 8:38
 Re: Carbies
Nice motor, I dream of having that twin DCOE set up.BTW, any real advantages, noticeable benefits in using an electric fan as in this Dato and riddin' the car of the stock fan?
Now that I am at my engine, might do that. I am getting rid of extra weight too, the air conditioning bracket, I got rid of the air conditioning compressor and radiator long time ago, and just saw the heavy compressor bracket still holding on. Also, I am canceling the car heater, here in California I do not need heaters,as well as air conditioners, it gets cold sometimes, but nothing a good jacket can not take care off. I will close the head port for the water to heater hose and also use a rubber cap to seal off the other side pipe. I do not need dirty crap comming out of the heater into my new radiator/waterpump/flushed system.
Jaime
ang94541
Posted: 2003/6/18 1:57  Updated: 2003/6/18 1:57
 Re: Carbies
All that smog keeps SoCal warm, right?
What if you just bypass the heater with a hose instead of blocking the passages? I would think that letting some water flow to the backside of the head would help keep temps even across the head.
I don't know. I just thought I'd throw that out.
converted
Posted: 2003/6/18 2:50  Updated: 2003/6/18 2:50
 Re: Carbies
Yep I agree, John Taylor says on racing A series, never to block the back water passage as it will cause a hot spot in the head and eventually crack it or blow the gasket.
Team_Dat
Posted: 2004/4/28 6:14  Updated: 2004/4/28 6:14
 Re: Carbies
good thing i read this thread, got to go to my mates this arvo and unplug his we just blocked them off cos he didn't want his heater, so you say just run a hose around the back of the engine?
oh and jaime, the bonus of removing mechanical fan is a small HP gain and the fact you can set the thermo fan to come on at a certain temp and then it can keep running when the car is turned off until the tempo is to where it should be. and it looks wank
sorry but
how 80's is that rocker cover.
no offence to any 80's styling car buffs
1200GXman
Posted: 2004/4/28 6:45  Updated: 2004/4/28 6:45
 Re: Carbies
Hi guys.
I read here that one should not block off the heater hose at the back of engine.
If you do block it of, is'nt it the same as you just closing the waterflow to the heater inside?
Or am I correct in thinking the flow still continues through like normal even when heater is closed but when opening the heater inside the water flows through a other pipe to the heater radiator.
ang94541
Posted: 2004/4/28 7:51  Updated: 2004/4/28 7:51
 Re: Carbies
water will not flow if you turn the heat down inside the car. I leave mine open all the time, especially when it's hot out.
How backwards does that sound?
nzdatman
Posted: 2004/6/28 9:29  Updated: 2004/6/28 9:29
 Re: Carbies
just stumbled across this in the photo section...
Yep I agree, John Taylor says on racing A series, never to block the back water passage...
Is this true?? Like someone else said, isn't it just the same as having the heater turned off? Is that a bad thing?
LittleFireyOne
Posted: 2006/8/11 11:55  Updated: 2006/8/11 11:55
 Re: Carbies
what about having the setting on heater but the heater fan not actually on, would that still work?
datsun120ycoupe
Posted: 2007/3/6 3:08  Updated: 2007/3/6 3:08
 Re: Carbies
lovin the rocker cover, how did you get that sort of effect?
1200rallycar
Posted: 2003/6/15 7:47  Updated: 2003/6/15 7:47
 Re: Carbies
what motor is it?
edit never mind it says a15 in other pic
B120dat
Posted: 2003/6/15 10:29  Updated: 2003/6/15 10:29
 Re: Carbies
what raditator is that off?
1200rallycar
Posted: 2003/6/15 11:03  Updated: 2003/6/15 11:03
 Re: Carbies
looks like my gemini one
B120dat
Posted: 2003/6/15 11:06  Updated: 2003/6/15 11:06
 Re: Carbies
sure it is
1200rallycar
Posted: 2003/6/15 11:11  Updated: 2003/6/15 11:11
 Re: Carbies
what do you mean?????
hey is msn working for you?, my password aint working and im sure i have it right
1200rallycar
Posted: 2003/6/15 11:12  Updated: 2003/6/15 11:12
 Re: Carbies
i just checked the pics of my mates gem and it actually does look diffrent so there ya go
B120dat
Posted: 2003/6/15 11:15  Updated: 2003/6/15 11:15
 Re: Carbies
assupumtions are the mother of all F%ck ups lol jokes
umm yeah msn is working for me, just close it down and start it up again
