Main : Mechanical : Engine missing carbie parts
[<   Previous  2044  2045  2046  2047  2048  2049  2050  Next   >]
missing carbie partsPopular
SubmitterjimmyjazzMore Photos from jimmyjazz   Last Update2008/5/10 4:54    Tell a friendTell a friend
Hits3007  Comments3    0.00 (0 votes)0.00 (0 votes)
Will emission carb run better than this?
Posted: 2008/7/14 7:12  Updated: 2008/7/14 7:12
 Re: missing carbie parts
It should run OK like this, you may not notice any improvement with the missing items finished, but there will be less pollution.
1. Servo, probably the Throttle Opener. It keeps the throttle open a bit on overrun to more completely burn the fuel. Emission control only.
2. PCV, keeps fumes out of the air you breath and ventilates the crankcase. It is good to have this.
3. Anti-diesel. Only needed if the engine keeps running when you turn the key off. Older models don't have it.
For more details, see: Emission Controls
Dundee1000
Posted: 2008/7/14 8:36  Updated: 2008/7/14 8:36
the Idle circuit will be blocked off without the anti Diesel solenoid working...
