Main : Mechanical : Engine reducing-diameter manifold
[<   Previous  2034  2035  2036  2037  2038  2039  2040  Next   >]
reducing-diameter manifoldPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2008/5/20 6:30    Tell a friendTell a friend
Hits2923  Comments9    0.00 (0 votes)0.00 (0 votes)
You know you want one
kululadotgroen
Posted: 2008/5/20 8:59  Updated: 2008/5/20 8:59
 Re: reducing-diameter manifold
If the transition from the large pipe to the smal one is smooth inside, then these will excelerate the inlet gasses a great deal. It should give good mixture and spread in the chamber, which should give a nice torque figure.
wolki101
Posted: 2008/5/20 9:11  Updated: 2008/5/20 9:11
yeh that makes sense. so is it more for the torque down low then?
kululadotgroen
Posted: 2008/5/20 9:29  Updated: 2008/5/20 9:29
I think the reducing diameter was more a consequence of the way the manifold had to be made than intentional...
steveo
Posted: 2008/5/20 11:23  Updated: 2008/5/20 11:23
'VERY NICE!' As Borat would say!
Looks like they're for mikuni's or something similar?
I could be wrong.
D
Posted: 2018/6/27 12:03  Updated: 2018/6/27 12:03
From: under the Firmament LOL no twiglight effect BS
artisan quality of yesteryear, today this kind of work scares many
Posted: 2018/7/1 22:30  Updated: 2018/7/1 22:30
I think Kulula's hit it on the nail
If you start with stock 28mm ports, and your bike carbs are 32mm, then a reduction is necessary
Intentionally done it raises low-speed power, put lessens top-end power. So less HP
cheater_5
Posted: 2008/5/20 6:46  Updated: 2008/5/20 6:46
looks like motorbike carb setup. interesting pipes
sidedraught
Posted: 2008/5/20 8:09  Updated: 2008/5/20 8:09
Shame its for a round port head.
wolki101
Posted: 2008/5/20 8:33  Updated: 2008/5/20 8:33
whats the reason for the reducing diameter pipes?
