Main : Misc H150 LSD
[<   Previous  1362  1363  1364  1365  1366  1367  1368  Next   >]
H150 LSD
H150 LSDPopular
Submitterclyons8More Photos from clyons8   Last Update2008/6/10 10:51    Tell a friendTell a friend
Hits3556  Comments10    0.00 (0 votes)0.00 (0 votes)
Here it is Andy/Dodgeman.
WhiteSedan
Posted: 2008/6/10 11:00  Updated: 2008/6/10 11:00
 Re: H150 LSD
You need teeth to work out the ratio...
clyons8
Posted: 2008/6/10 10:53  Updated: 2008/6/10 10:53
 Re: H150 LSD
Still unsure about ratio due to language barrier.
sidedraught
Posted: 2008/6/10 11:02  Updated: 2008/6/10 11:02
 Re: H150 LSD
If thats it, it doesnt have a crownwheel and pinion so you would have to provide one, and with it the ratio.
LittleFireyOne
Posted: 2008/6/10 11:09  Updated: 2008/6/10 11:09
 Re: H150 LSD
Not a bad looking business card either. Would that be a hardened alloy unit or steel? I can't really tell
clyons8
Posted: 2008/6/10 11:20  Updated: 2008/6/10 11:20
 Re: H150 LSD
No crownwheel or input pinion in the pictures.
1.5 W is mentioned alot. No idea what that could mean.
Tyrie
Posted: 2008/6/10 11:39  Updated: 2008/6/10 11:39
 Re: H150 LSD
I guess that measn its a 1.5way LSD, something about when it spins both I think.
Is this an aftermarket part?
cheater_5
Posted: 2008/6/10 11:41  Updated: 2008/6/10 11:41
 Re: H150 LSD
haha ZINNNGG
CHECK IT OUT
Dodgeman
Posted: 2008/6/10 14:30  Updated: 2008/6/10 14:30
 Re: H150 LSD
Hmmmm, doesn't look like mine, so is probably not a Nismo unit.
The ratio is whatever available one you want it to be. If it's an H150, then it could be 3.9. 3.7, or 3.54 to 1, or any one of a number of Nismo ratios that are still on offer.
If this is on a site somewhere, then please e-mail me a link [discression assured] as I can probably translate it, ... after a fashion.
E-mail link is at the bottom of this post.
perthute
Posted: 2008/6/11 3:41  Updated: 2008/6/11 3:41
 Re: H150 LSD
1.5 way is lsd , works under load
2 way work under load, if you back off the gas it grabs two wheels and if you turn it grabs two has well ,
Posted: 2017/8/16 5:17  Updated: 2017/8/16 5:17
 Re: H150 LSD
Hmmm. Car Wash brand (裕隆)
