Main : Mechanical : Drive Train 5-speed comparo
[<   Previous  733  734  735  736  737  738  739  Next   >]
5-speed comparo
5-speed comparoPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2003/6/21 7:17    Tell a friendTell a friend
Hits6292  Comments3    0.00 (0 votes)0.00 (0 votes)
F5C56A (left, B110) and F5W60L (right, B310). more pics at http://www.f4.dion.ne.jp/~testa444/mit-1.htm
b310gx
Posted: 2003/6/22 12:16  Updated: 2003/6/22 12:16
 Re: 5-speed comparo
some interesting things to note, the drain plug on the 56a box is out the bottom of the sandwich plate,the differences between the gearbox mount positions,& how much further back the bellhousing is on the 60a.they are also the same length.oh,& the reverse light switch on the 56a box is in an unusual position on the rear housing.plus,56a's blow cluster gears if you put a serious amount of horsepower through them.
B120dat
Posted: 2003/6/21 8:04  Updated: 2003/6/21 8:04
 Re: 5-speed comparo
F5W60L, is this the 60a gearbox? or are they different boxes? cause i got a 60a
B120dat
Posted: 2003/6/21 8:07  Updated: 2003/6/21 8:07
 Re: 5-speed comparo
arrh i just read in the other pic the 60L is early version and 60A is the late version......
