Main : Mechanical : Engine A10 Engine, left side
[<   Previous  623  624  625  626  627  628  629  Next   >]
A10 Engine, left sidePopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2014/12/31 8:31    Tell a friendTell a friend
Hits3518  Comments2    0.00 (0 votes)0.00 (0 votes)
Most notable feature is lack of a breather pipe hole at the back of the block.
See A10 Engine
Dodgeman
Posted: 2008/8/26 17:07  Updated: 2008/8/26 17:07
 Re: A10 Engine, left side
This one has a non correct oil filler cap as the original had provision to filter the air that was drawn into it to replace the fumes drawn out through the draught tubr at the back that in turn drew the fumes from the fitting at the rear of the rocker cover.
This cap is the sealed type used on all other A series engines.
